Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 08-13-2009, 09:25 PM
minicrazy592's Avatar
minicrazy592 minicrazy592 is offline
about the mini part....
Mein Auto: E90 M-tech, E30 M-tech
X3 Cup Holder Removal/Replacement DIY
So I wanted to remove my cup holder to clean it and the area underneath it. X3 cup holders have the same coating as E46's and in turn like to peel with age. So some may want to replace it here's how.
If you want to replace it.....
Part Numbers:
Gray: 51163404801
Beige: 51163404802
Black: 51163404799
Those are the numbers for 04 models, but I doubt they have changed
Disclaimer: I took these pics before I cleaned it
Step 1, grab the left side of the cup holder grasping it with your thumb on the outside. Then pinch the side of the cup holder......
Step 2, while pinching the cup holder, lift away from you and twist with a counter clockwise motion. It should pop right out.
Look at all that nasty old coffee and coke
Here's a video if you don't get it
For all those wondering what the cup holder looks like, here you go....
To clean your cup holder, choose a cleaner that's gentle and doesn't have any harsh chemicals in it. The coating on the plastic is sensitive and can peel while you are cleaning it if you use something harsh. I use Method All Natural and All Surface from Target for cleaning the plastic bits in my X3. A bonus of it is a nice clean smell.
To re-install
Step 3, insert the rear of the cup hold back into its place first. Make sure that the tabs on the back are under the rest of the center arm rest.
These tabs
Step 4, apply pressure to the front and the front clips should pop right in.
Once again, a video if you don't get it
Congrats, you know have a clean/new cup holder
An alternative
-J.T.
Will be missed: 04' E83 M54B30
Old 08-16-2009, 02:57 PM
delmarco's Avatar
delmarco delmarco is offline
Quality
Send a message via Yahoo to delmarco
Mein Auto: 2011 335xi Deep Sea Blue
lol.
That is the MOST DETAILED DIY I've ever seen for removing and cleaning a cup holder...
great job.
VISIT MY GARAGE TO SEE ALL MY MODS:
http://directory.e46fanatics.com/use...rMod&UcId=7917
Old 08-16-2009, 04:42 PM
Thanks. I figured if it was overly detailed there would be no questions.
-J.T.
Old 08-23-2009, 09:03 PM
oilfighter oilfighter is offline
Mein Auto: Car
I wish everyone would do this kind of DIY. The video would really help put words into perspective. Nice job!
Old 08-23-2009, 11:04 PM
-J.T.
Old 09-02-2011, 08:22 AM
SpartanGA SpartanGA is offline
Mein Auto: 2007 550i, 2011 335i Vert
Great thread. I was able to remove and clean plus one of those 'fingers' was stuck and I was able to pop it back out. Good as new except for the peeling paint.
Jim
2007 550i Sport - White - Tan
Old 09-12-2011, 11:00 PM
This reminded me of my old X3.
-J.T.
Old 12-28-2011, 08:42 AM
wamcneil wamcneil is offline
Mein Auto: 2006 X3, 2001 330Ci
These instructions are wrong. Sure, you can remove it as instructed; but you could also remove it with a hammer or crowbar.
When removed in this manner it will damage and/or break the retaining tabs at the back edge of the cupholder. There are horizontal tabs on the rear edge that slide back under the edge of the console, and then tabs on the front edge that clip down into the console. The rear tabs are NOT designed to be wrenched upward and if you look carefully at the pictures (pic #8?) you can see they are cranked at an angle from being torn out of the console.
If you curl your fingers around the front edge of the cupholder and press in on the bottom edge (pressure toward the rear of the car) while rolling your fingers to pull up on the front of cupholder, the clips will release and allow the front to come up, then it will come out easily without trauma to the rear tabs.
Replacement is just as described in the original post.
