E30 (1982 - 1993)
Old 08-14-2009, 08:28 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Temp issues
The temp gauge sits at 3/4 once the engine is warmed up, when i drive her hard shes going up to the red, and wont come back down.
New water pump, fresh coolant. i think there might be a block in the block? or something? the car has always sat just over (read marginally) half way ever since owning the car, but its got to the stage its at now. how can i test for/fix a blockage? the radiator is clear (flushed it while i had out for the TB/waterpump). any other ideas? ive swapped the thermostat with the one from my parts car so either they are both dead (unlikely?) or its something else.
plz help
btw steve going to the yard in an hour or so, so ill PM you when i get back
Edit: I have a CAI (aka HAI), but as i said, the car was running high to start with, before i put that on. i know that isnt probably doing the car any favours having that but im going to move that/make a heat shield
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 08-14-2009, 09:06 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
Originally Posted by ethrty View Post
btw steve going to the yard in an hour or so, so ill pm you when i get back
im hoping for good news
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 08-14-2009, 11:16 PM
bad news most BMWs ive ever seen at the yard but only one facelift E30.
ill keep my eyes and ears open for sure though. theres a guy i know who wrecks BMWs for a living, and i know hes got a few sets of bumpers, but i dont know if he will seperate the trim :/
E30 above Sold
Old 08-15-2009, 12:03 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
Saw my friend take an air compressor to the topside of his motor a few weeks back and brown sludge came out the bottom, idk if its a good way to "check" but its worth a try if you havent already
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 08-15-2009, 12:48 AM
lol att first read i thought you meant like bashed the top of the motor with the tank... dissapointed to assure mysefl it wasnt lol
E30 above Sold
Old 08-15-2009, 09:38 AM
fcsteve's Avatar
610EUROs
bummer
Old 08-15-2009, 04:35 PM
bummer
check your pm's
E30 above Sold
Old 08-15-2009, 04:36 PM
does anyone have an idea about my problem??
E30 above Sold
Old 08-15-2009, 05:13 PM
Zer0z4 Zer0z4 is offline
Mein Auto: 87 bmw 325
maybe the thermostat is no good, or u didnt bleed the system all the way. Maybe u messed something up when u swapped trannys.
Old 08-16-2009, 01:23 AM
does anyone know how to test the temperature sender, if thats possible? or in fact where that actually is? lol noob question
wouldnt have come from the traanny swap itself. but i did to the t/belt and waterpump at the same time
E30 above Sold
Old 08-16-2009, 01:40 AM
yeah i didnt mean because of the swap itself, i just meant maybe u moved something and didnt put it back.
Old 08-16-2009, 02:02 AM
i see. i didnt have to unplug any electrical stuff at all, bar the shifter assembly
E30 above Sold
Old 08-17-2009, 05:57 AM
dlmpsy's Avatar
dlmpsy dlmpsy is offline
Mein Auto: 1990 325is
Did you bleed the system? Check the fan clutch?
Old 08-17-2009, 06:36 AM
1979Marshall 1979Marshall is offline
Mein Auto: 1985 325e
Got some ideas. It might be long winded so I'm pm you after I get some stuff done at work and have time.
But for starts, start by finding out if your car is actually running hot. I don't know if there are resistance plots for the thermistors which are your sending units. Resistance changes as temp rises....Bentley or the internet might know that, but you should still cross ref. that with an infrared gun. Do buy one today and you can know for sure your car's over heating.
Just don't kill it on the way to the store and blow the head gasket. Thats a bad way to begin rebuilding your engine.
But i think this sounds like a water pump issue.
Old 08-17-2009, 02:12 PM
im leaning towards a dodg sender or there being an air bubble in the system, but im not sure how to get it out. Where is the temperature sender? The car has always run over the center line. so its possibly more likely to be that?
E30 above Sold
Old 08-17-2009, 08:56 PM
East Bound And Down
could be the sender, or just the temp sensor! I believe its the very front sensor, havent ever had one go out on my E30's but a dodge shadow my cousin had the sensor went out and sat on the red after warming up.. we checked everything, then i checked the sensor resistance and that was the problem... 8 dollar fix
just for you
8 US Dollar = 11.95422 New Zealand Dollar
Old 08-18-2009, 04:20 AM
just for you
im not sure i know where you mean sorry. god i feel noob lol. is it on the radiator? the only electrical thing that goes to there on my car is the thermostat?
E30 above Sold
Old 08-18-2009, 08:09 AM
East Bound And Down
yeh there are three sensors on the top of the thermostat housing 1 blue, 1carmel colored, 1 brown.... i think its the brown one but check in haynes
Old 09-13-2009, 07:51 PM
ridefree89hd ridefree89hd is offline
Mein Auto: 90 525i e34
ive experianced overheating problems on both my 90e34 and 87e30 after doing waterpump / t-stat changes and found that burping system thru the bleeder on t-stat housing doesnt always work the first time. i actually had to park on an incline (front up) bleed and refill several times for bubble to clear. good luck.
Old 09-13-2009, 08:03 PM
ive experianced overheating probs after waterpump/t-stat work on both my 90e34 and 87e30 and found using the bleeder on t-stat housing is not always effective removing air bubbles, i actually parked on an incline (front up) and had to bleed and refill several times for prob. to clear. good luck
Old 09-13-2009, 08:18 PM
downhiller's Avatar
livin large
did you do a coolant flush when you did the tb? i mean a full flush, not just the radiator, but bolck as well
Old 09-13-2009, 10:09 PM
No i didnt. i wish i had. I changed the sender and tightened the bolts on the back of the gauge cluster and now the gauge sits at just shy of 3/4 all the time, ie it doesnt ever jump around anymore. so either its the wrong sender or im not getting efficient cooling still. I hard wired the auxilary fan on so that runs all the time the car is on to help cooling, but still no luck. I dunno what the hell is going on.
E30 above Sold
Old 09-13-2009, 11:01 PM
downhiller's Avatar
livin large
well you can have a couple issues, too much fuel, or a sticking t-stat. to test a t-stat, put in a pot of water with a thermometer to measure water heat. put on stove and set stove to high. wait til t-stat opens and look at thermometer. compare reading with oe specs.
too much fuel part, that goes into other temp sensors, o2 sensor and whole bunch of other stuff. go cheap first, get a new tstat.then go from there
Old 09-14-2009, 03:25 AM
The second thing jumps out at me. my fuel economy is really bad. i mean REALLY bad. i thought it was normalish (less economical than my old Sentra but thats coz bigger engine/bigger car etc). What should i be checking? i will check the thermostat on wednesday in the mean time
E30 above Sold
Old 09-14-2009, 08:12 AM
danielw05 danielw05 is offline
Send a message via AIM to danielw05 Send a message via MSN to danielw05 Send a message via Yahoo to danielw05
+1 on burping the system once or twice...
http://bimmerfest.com/forums/showthr...highlight=burp
