E90/E91/E92/E93 (2006 - 2013)
Old 08-17-2009, 12:21 PM
Chaseme Chaseme is offline
Mein Auto: MKVGolf,R6,MCoupe,325Tour
N52 and N54, what really is the difference?
Obviously, the N54 has twin turbos, but what is the difference in build?
In other words, are the heads, crankcase and all that stuff the same for both cars?
I imagine the fuel pump is different. Anything else?
Old 08-17-2009, 12:25 PM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
They are completley different motors down to the block. Different everything.
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms|
2009 X5 3.0 - AW- Black Dakota/Bamboo | Premium |Tech | Cold Weather | Ipod | Rear Climate |
07 X3 - Sold
07 335 coupe - sold
Old 08-17-2009, 12:27 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Very very different engines - N52 is actually the more advanced design, lighter with magnesium and aluminum constuction, N54 is also a 2 piece design, but an all aluminum engine, so block, heads, intake, pretty much everything is different except some of the accessories that bolt onto it, like the electric water pump, alternator etc. N54 is also direct injection, so has 2 fuel pumps instead of just a low pressure one.
2008 335i Vert Montego/Saddle/Grey Poplar
2014 X3 35i Space Grey/Chestnut/Fineline Wave
Old 08-17-2009, 12:28 PM
bmw325 bmw325 is offline
Mein Auto: 335i
No. The n54 is all aluminum (and allegedly the same block as the m54b30)
the n52 uses the newer magnesium aluminum block. Also the n54 also uses direct injection while the us n52 uses valvetronic with regular injection.
http://nyccarblog.blogspot.com/
Old 08-17-2009, 12:35 PM
hpowders hpowders is offline
IRS SUCKS!!!
Mein Auto: E90, Porsche 911, VW GTI
Fuel pump? Did he say fuel pump?
There is no more beautiful car on Bimmerfest than my gorgeous Forest Green Porsche 911 coupe!
Obama is an incompetent liar!
Porsche: Accept no substitute, unless you're poor!
The E90 sedan is the last in the line of great 4 door 3 Series BMW's. Too bad.
"The VW GTI remains and will likely continue to be one of the finest compact sports cars in the world." Christian Seabaugh, Motortrend, March 27, 2012.
06/02/2005-03/02/2013: 7 3/4 Great years on Bimmerfest!!!
Old 08-18-2009, 08:47 AM
RambleJ RambleJ is offline
Mein Auto: 2012 535i M-sport
I love my fuel pump, and the 3 other ones that have failed on me.. To this day still does not drive me away from my car or have me thinking "I should have chosen another slower car"
Old 08-18-2009, 02:25 PM
invariant's Avatar
invariant invariant is offline
Mein Auto: 2008 335i
* The N54 has all aluminum crankcase with iron cylinder liners. The aluminum crankcase is pressure cast and differs from the "insert" design of the N52. This design is in contrast to the previous composite magnesium/aluminum crankcase on the N52. The construction of the N54 crankcase is to accommodate the increased torque output of the turbocharged N54.
* The N54 has the forged steel crankshaft (stronger) as opposed to the cast iron crankshaft in the N52.
* The N54 does not use valvetronic unlike the N52.
* Piston shape design in the N54 is different from the N52 to meet mixture formation requirements
* Crankcase ventilation system is different
* Both engines have an electric coolant pump, but the N54 has a 400W pump (9000 l/h), while the N52 has a 200W pump (7000 l/h)
For details see this sticky thread at e90post: http://www.e90post.com/forums/showthread.php?t=38856
2008 E90 335i 6MT + SSK + CDV-delete / ZSP / aluminum / black leather / Conti DW + compact spare / integrated portable nav plus
2005 E83 X3 Auto
Old 08-18-2009, 08:53 PM
jwac's Avatar
jwac jwac is offline
Mein Auto: 335i Coupe 6MT
That's not true although it was rumored - the N54 is a completely new block design, unrelated to the previous-gen M54.
2011.5 335i Coupe 6MT
Space Gray | Black leather | Bamboo Anthracite
Premium | M Sport | Convenience | Nav | Heated Seats | Harman Kardon | Auto High Beams | V1 Power Kit
09.05.11 European Delivery
Past:
2010 135i Vert 6MT
2007 335i Coupe 6MT
2006 325i Sedan 6MT
Old 11-25-2011, 08:51 AM
ishareit ishareit is offline
Mein Auto: 2008 535xi
valve gasket replacement DIY (N52 vs N54)
I was looking for a valve cover gasket replacement DIY and then only DIY I could find was for N52. What I have is an N54. Do you think that the DIY for N52 would also apply to N54? Thanks!
Here is the DIY for N52: http://forums.5series.net/topic/1151...with-pictures/
