E30 (1982 - 1993)
Old 04-07-2012, 07:15 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
n00b question. were E30 tourings available in the USA?
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 04-07-2012, 09:32 PM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
Not sure id think so but I've also never seen one they stopped production of the e30 in 94 with the touring so you think there would be a few around
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 04-08-2012, 08:38 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
Originally Posted by Ethrty View Post
finger tight. done.
thats the precision answer i was looking for
no, the few that are here were imported from other countries.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-08-2012, 02:07 PM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
Steve, is it the m52 or m52tu with the aluminum block? Both are 20nm, but the iron block takes 50 degrees and the aluminum takes 70 degrees.
Wide Open Throttle Technologies (WOT-Tech)
Instagram feed
Facebook page
Old 04-08-2012, 02:17 PM
fcsteve's Avatar
610EUROs
m52, not the aluminum block.
so 15ftlbs and 50 degrees ?
Old 04-08-2012, 03:16 PM
unless you are in euroland, then they are both aluminium
E30 above Sold
Old 04-08-2012, 05:01 PM
I looked in the BMW torque procedure .pdf and that's what it said. Check to make sure they are the 10mm and not 11mm mains, if 11mm it's different. I don't have AllData online anymore, but still have the CD's loaded at the shop PC and can double check for you when I get in tomorrow, but yes, 20nm and 50 degrees - approx 15ft/lb. Your wrench doesn't have metric and SAE values on it?
Instagram feed
Facebook page
Old 04-08-2012, 07:43 PM
fcsteve's Avatar
610EUROs
no NM, only m kg and ft lbs
Old 04-09-2012, 08:30 AM
Confirmed. 20nm + 50 degrees.
That the AllData tables are an exact copy of the BMW manuals, actually, never paid much attention.
EDIT: Bentley also matches.
Instagram feed
Facebook page
Old 04-09-2012, 08:42 AM
fcsteve's Avatar
610EUROs
i really need to pick up an e36 Bentley
Old 04-10-2012, 07:52 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
Dammit what am i supposed to do with this!!!!
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 04-10-2012, 08:34 AM
I have one of those too lol. Customer overheated the car, block and head warped, replaced it with a take-out. Got it for $100 (just paid the core).
Instagram feed
Facebook page
Old 04-10-2012, 04:27 PM
Article: http://www.stuff.co.nz/national/6721...s-crash-driver
One of NZs new websites
Tui is a beer, and they have all sorts of Yeah Right billboards, usually with all manner of local current events.
E30 above Sold
Old 04-10-2012, 09:55 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Give it to me? lol
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 04-12-2012, 10:43 AM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
4.10=blahh. Not a huge fan of how low first is.
Old 04-12-2012, 12:04 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Is it bad if I like my 2.79 lsd rear end? Just seems like it flows with the trans real well. I had a 3.45 lsd in my e36 and it felt too highway-e if that makes sense lol. In my e30 I can pretty much stay in 3rd on the highway if I wanted to ha.
Old 04-12-2012, 06:51 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Not a bad thing. We might call you old though
My e30 had 4.10 out back and 3.73 in the front. That thing moved like hell though. My launches consisted of no chirping or smoke. Just go
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 04-13-2012, 09:48 AM
East Bound And Down
how did your transfer case like that???
Old 04-13-2012, 10:11 AM
Newman271's Avatar
That Guy
I was just wondering the same thing lol.. Transfer cases are tricky bastards ha. I had a 95 talon tsi, with a buschur 50/50 transfer case and it was almost not road worthy. Turn the corner under boost and get ready for all 4 to light up and cause that quick corner to a quick donut lol... but I also busted a 11.4 out of it with 22 pounds on a big 16g turbo. Fun in a straight line. Thats why I went to bimmers fun in a straight line or hugging corners.
Old 04-13-2012, 06:39 PM
fcsteve's Avatar
610EUROs
who knows some tricks to remove cosmoline ? ive been trying to find a good solvent or cleaner online. everywhere says gasoline and such which can damage the paint. i dont want that.
Old 04-13-2012, 08:23 PM
The way you reply to people's threads, I thought you knew everything?
J/K
There are a few ways I found, but if left too long, it will ruin your paint.
Heat gun and Simple Green (Formula88 is best if available in your area), oven cleaner, or gas will work, but needs to be removed immediately to avoid staining.
If gas was so quick to ruin paint, then a lot of cars would have drips of bare metal below the gas cap.
Heat and dish soap works with a LOT of elbow grease.
I have been thinking about purchasing the HF steam cleaner/wall paper remover, but haven't yet. I know a lot of weapons/gun nuts put parts in the dishwasher and it works well, but engine bays don't fit easily...
Instagram feed
Facebook page
Old 04-13-2012, 08:40 PM
fcsteve's Avatar
610EUROs
i do know everything, except the things i don't know
i tried gas when i was doing the bronzit's engine bay. it softened the paint very quickly and even the soft rubbing with a paper towel was rubbing into the clear coat. the car is silver and has a heavy gold(cosmoline)engine bay.
Davey said he was trying simple green/heat and it wasnt coming off easy at all.
steam seems to be the easiest way, but i dont have a way to steam clean or heated pressure wash the bay.
i have no intention of painting this engine bay so the paint can't be damaged.
Old 04-13-2012, 10:15 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
well since the diffs were stock, it worked out fine. 64% power to rear and 36 front. prolly has something to do with it
Old 04-13-2012, 11:16 PM
wow i would have assumed they were the same front and back
E30 above Sold
Old 04-17-2012, 07:31 PM
East Bound And Down
Sorry i must have been tearing into jeeps transfer cases too long because i thought....
BMW transfer cases had essentially an internal diff with bands that distributed power how the engineers designed them too...
-*nga*-, e36 has best forum, e36 rules
