Old 07-05-2016, 01:45 PM
Izzys2001Z3 Izzys2001Z3 is offline
Mein Auto: 2001 Z3 3.0 5-spd.
Rattle from driver side rear wheel
Whenever I'm going over broken pavement, I hear this annoying rattling SOUND coming from the driver side wheel area, that I can't trace when the car is stationary. Anyone have a similar experience or suggestions on what may be causing this? 2001 3.0i MT.
Sent from my A0001 using Tapatalk
Old 07-05-2016, 01:54 PM
oceandiver86's Avatar
oceandiver86 oceandiver86 is offline
Mein Auto: z4
did you check your sway bar links and bushes?
Old 07-05-2016, 02:03 PM
Yeah those look fine. Found another related thread which says RSM or parking brake cable. I'll check those next.
http://www.bimmerfest.com/forums/showthread.php?t=27873
Old 07-05-2016, 03:16 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
Not sure what type of wheels you have, but sometimes the center caps can rattle when going over bumps.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 07-05-2016, 03:30 PM
Def. not the wheels since I swapped the wheels out for new wheels, same noise. Good suggestion though. Brake pad shims and parking brake are leading candidates right now. Parking brake should be easy enough to check as if you pull on it gently while going over the bumps (at a safe speed) noise should go away.
Old 07-05-2016, 05:11 PM
Mein Auto: 1998 Z3 Roadster
Upper rear shock mounts are the most common culprit.
I've also heard of at least one case caused by rubber spring pads.
The absolute worse case would be the differential mount at the trunk floor.
