Old 08-21-2009, 12:27 PM
racingxtsy racingxtsy is offline
Mein Auto: E85
Arrow Z4: Unclog the drains on the soft-top?
We just had tons of rain in Toronto, ON and I am hearing the sound of water when driving. I quickly checked the luggage compartment / trunk and there is no water in there.
I found these instructions to unclog the drains on the soft-top: http://www.zpost.com/forums/showthread.php?t=63033
It sounds like I am on a boat
Does this sound like I need to unclog the drains on the soft-top to let water escape, or is this normal after it rains a lot?
Any tips or advice, etc. would be greatly appreciated. Thanks!
Old 08-21-2009, 01:59 PM
12thBMW 12thBMW is offline
BMW Only Since 1972
Mein Auto: '06Z4, '05X3
Don't Need to Remove Splash Guard
The last poster on the Z-Post Thread said that you can see and reach the drains through a rectangular hole on the splash guard. Is that true ? (my Z4's in the shop, so I can't check right now). If it is, racingxtsy when you get under there, takes some clear, well-lit pictures of it and post them for the rest of us. Thanks....
Actually:
Driving 13th(E83) & 14th(E85) BMW's
Retired: 12 BMW's (1800, 2002, E30x3, E34, E36x2, E39x2, E46, E83)
Current: 7 BMW's in Family
Old 08-21-2009, 02:59 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
You can see the right side drain holes but NOT the left side. The left side is hidden under the hydraulic motor.
Here is a couple of pics of the holes with the top out of the car..
Right Side:
Left Side:
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 08-21-2009, 08:23 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
Yes, you can see the drains from underneath, the outlet is the rubber "star' like object you can see if you look through the rectangular hole in the splash guard at the right angle, in front of the rear wheel. A soft pipe cleaner or similar can be fed in from underneath, if you bend it the right way.
Old 08-22-2009, 01:44 PM
Mein Auto: E85
Yes, you don't have to take any plastic covers off to remove the drain plug underneath. This should save people from breaking and replacing the rivets.
Just jack the car up using a low profile jack (mine barely made it) and use jack stands (1) to secure the vehicle.
Crawl underneath and look for a rectangular shaped cut-out in the plastic, right by the rear wheel.
At the right angle you should see a black round drain plug in the top left hand corner. You can see a picture of it in the link I posted above. Pull the drain plug straight out. Some leaves and crap should come out.
If you have a pipe cleaner you can fish it up there to free up any debris, and allow for the proper flow of water. I didn't have any pipe cleaners, so I used a nice thin, strong branch from my mulberry tree!
If you can use compressed air (or vacuum cleaner in reverse mode) it would work best, just follow the directions in the post above, but don't bother removing the plastics - it's a waste of time.
In the end, I think I overreacted and the "water noise" I heard was likely the gas in the gas tank.
Thanks for your helpful responses.
Old 08-22-2009, 02:06 PM
shipkiller's Avatar
Mein Auto: Me
Here is a link for a How-To.
Old 08-22-2009, 10:43 PM
cruisingdog cruisingdog is offline
Mein Auto: z4 2.5i roadster
Has anyone tried a can of 'air' like the ones used for cleaning computer keyboards and the like. It might be the easy solution ! Either that or a pressure hose to force the debris down.
I have a question about the star thingy. Why is it there (I'm guessing to stop the crap from flowing upward from the road whilst driving) . There must be a better solution. Maybe an open hole (open rubber tubing) with a splash guard over it to stop the upward thrust of road water from the wheels.
2005 Z4 2.5i
Old 08-23-2009, 12:28 PM
shipkiller's Avatar
Mein Auto: Me
Canned Air is not powerful enough, at least to me. I used my air compressor..along with flushing the debris out with water.
Old 01-09-2012, 12:46 PM
BZN Z3 BZN Z3 is offline
Mein Auto: Z3 and Z4
Any chance of re-posting with the pictures, or e-mail to bwmoffit@hotmail.com?
Old 01-09-2012, 01:49 PM
shipkiller's Avatar
Mein Auto: Me
http://www.shipkiller.com/General_Info_Page.html
Old 01-09-2012, 04:02 PM
jmanscotch's Avatar
jmanscotch jmanscotch is offline
is a Texan
Mein Auto: '04 530iA
THANKS a million, Shipkiller, been looking for more detailed photos for a while.
-Jake
2004 325Ci - 5MT - SOLD & MISSED
2003 3.0 Z4 - 6MT - SOLD TO HAIRDRESSER
1967 1602 - 4MT - STOLEN IN KY
2008 328XI - 6MT - LOST IN DIVORCE
1995 325i - A/T - RUSTED BACK TO EARTH
2009 135i - 6MT - COPS IMPOUNDED
1983 533i - 5MT - DROPPED, POPPED & SMASHED IT
2004 530i - A/T - OLD & LAZY: SLUSHBOX CRUISING
1973 2002 - 4MT - EVERLASTING PROJECT DRIVER
