Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 08-24-2009, 09:28 AM
533-3.8 533-3.8 is offline
Mein Auto: 1988 325ix '88 325ix
Latest problem, stripped diff fill plug
If there is a trick to get it off now I would like to know. My solution to filling the fluid is to jack the rear about 4 feet in the air and add the fluid through the drain hole. Any ideas?
Old 08-24-2009, 11:21 AM
craig3887 craig3887 is offline
Mein Auto: 325e
I stripped the drain plug on my diff. I think I used a large torx/star bit with a propane torch and was able to get it out with that way. I did this a few years back so I am not entirely sure how i got it off.
Old 08-24-2009, 12:06 PM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
It's a bit late to tell you this now, but this is why you always remove the fill plug before removing the drain plug. You don't want to end up in this situation.
As far as how to fix it now...how about a left-handed drill bit and screw extractor?
Old 08-24-2009, 12:43 PM
Your right, but all I did was loosen the bottom and the temporary solution is to fill it through the speedo pick up hole. The bottom needed a bar and pipe to loosen>
