big oil leak...... NEED HELP - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 08-28-2009, 03:47 PM
e30fettish e30fettish is offline
Mein Auto: 89' 325is
Noticed big oil leak last week when driving e30. When I looked under the hood, there was a massive oil build up near the oil filter housing and oil valve. I did some reading and a lot of people were telling me the oil valve gasket is a common problem, as well as the gasket between the oil filter housing connecting to the block. So I changed both and it did nothing for the leak. As I continued to look I started seeing oil drip down the oil sensor wire. The wire connects somewhere to the block and concluded that's where the leak is coming from. Does anyone have advice as to fixing the leak? any help is appreciated
Thank you
Old 08-28-2009, 06:45 PM
downhiller's Avatar
livin large
that would probably be your oil pressure sensor. new sensor and o-ring tends to fix problems.
Old 08-28-2009, 07:38 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
+1 Or you could just do away with the light and install a manual gauge as I did, or keep the light and install a manual/electric gauge.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
