Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-28-2009, 05:33 PM
daredream daredream is offline
Mein Auto: BMW 528e
528e key off, radio stays on??
I have a 1984 528e that runs great. Good commuter car. All of a sudden when you turn the key off the radio and overhead check lights stay on (possibly other things as well). It is draining the batt. I figured there must be a relay that has gone faulty but I do not see one that would make sense. I tested the ignition switch and that seems to be working correctly. Any ideas?
Old 09-02-2009, 11:13 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
To me is sounds like it is your ignition switch electrical part. To test it, you will need to remove the bottom cover of the steering column and disconnect the plug for it. You should measure the battery draw before you unplug it and after to confirm it.
Jimmy Moreno
1995 530i
1986 535i
1984 528e electrical, elec not turning off
HTML code is Off
