Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-28-2009, 07:38 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
87 528E Slushbox
I'm thinking of getting this. I have an 86 325E. Same motor right? Is the price right for this or what? I only know the 325. Do these automatics last as long as the Gertag manual?
http://norfolk.craigslist.org/ctd/1347542330.html
Old 08-29-2009, 06:10 AM
south26 south26 is offline
Mein Auto: 535i 1989
Hi,
the auto does not last as long as the manual. Many times the auto will have the a-pack fail, which causes it to loose all forward movement.
Andy
Old 08-29-2009, 06:19 PM
omw41's Avatar
Originally Posted by south26 View Post
Hi,
Andy
Thanks Andy. Is it an expensieve fix if it goes?
Old 08-30-2009, 06:15 AM
Most people just end up either getting rid of the car or doing a manual switch.
Andy
Old 08-30-2009, 10:54 PM
dbb10001 dbb10001 is offline
Mein Auto: 325ic, 528e, GLK350
Car looks great. I have one with around 150K that is running strong. Intuitively, the major components' lifespans are directly related to how the car is treated. Reward it, and it should reward you back. But be prepared to spend some $ on getting the car sorted out in terms of general maintenance. I took a risk and went for a cheaper one (some rust and very faded paint in spots) with a good engine and transmission for $800 but then spent $2800 having the front suspension assembly rebuilt, brakes done, water pump, cooling system, power steering rack, transmission mounts, timing belt, spark plugs, etc etc etc. It now runs great but it is at a significant cost. Unless that car has complete service records, plan on potentially spending some bucks getting it up to speed.
Old 08-31-2009, 07:40 PM
omw41's Avatar
I am feeling you. I am on my second 325E, and they don't come cheap either. I got a sweet one for 1500,and had to put about a grand into the front end, a new clutch, tires, rotors, stereo, etc...but now...I take the car on 2000 mile trips with no issues. I might still get the 528...I'll offer him 2 grand, after I look it over.
Old 09-02-2009, 11:10 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
The A-Clutch Pack fix is relatively cheap if you are willing to tackle it yourself. If you do a search on the internet for the 4HP-22 transmission you will find a repair kit for it. it shouldn't be more than a couple hundred of bucks if you go the DIY route.
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
