E30 (1982 - 1993)
Old 08-28-2009, 11:52 PM
BothersMyWife BothersMyWife is offline
Mein Auto: 89 325is
The right DME for my 89 325is.
How do I know if the computer for my e30 is the correct one? Somebody could sell me one, not knowing himself.......and leaves me with a bigger electrical problem! How do I compare the ref# on the DME casing:
Old 08-29-2009, 01:55 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
drop the driver kick panel or glove box depending on if the car is RHD or LHD respectively, and unclip the ECU and take out the 4 bolts. the number is printed on the top of it. im not sure which number is which though, but enter it into realoem.com and see if its the correct one. you will be able to find out what the number for the correct one is as well, should the one you have be wrong
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 08-29-2009, 06:19 AM
Mein Auto: 89 325is
Thank You "MASTER"
If I got a used DME, does it have to be coded for my car, or is it good to go. Thanks for your time and wisdom!
Old 08-29-2009, 07:34 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
any e30 DME of the same number will work properly.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 08-29-2009, 07:36 AM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
There is a wide variety of ecus for the e30 325i/s. 173, 153, 380, 525, 081, 351, 382, 524, 526, and probably more that I'm missing. All are interchangeable, all will work in your car. The only difference is the software version/revision. So to answer your question, no. They are all plug and play.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 08-29-2009, 08:38 AM
Mein Auto: 89 325is
You Rock!
Thank God for you and aspirin! Is there anything you guys don't know?
Old 08-29-2009, 03:51 PM
T.E.A.M. = Together Everyone Achieves More. Corny much? remembered that from when i was 7
E30 above Sold
Old 09-24-2009, 06:27 PM
mtntexas mtntexas is offline
Mein Auto: 1990 BMW 325ic
Lordofthewaters- I'm a little slow on the uptake due to nice drugs following heart surgery. I've PM'd you but I'm a neonate and thought maybe I should ask here... I've got a '90 325ic and a BMW tech told me that my 0 261 200 380 (1730575 001) is bad and I bought a replacement today from a wrecked '90 325i AUTO sedan. I got a 0 261 200 173 (1730575 001) and it still doesn't start. Should this ECU from an auto sedan work on my 5-spd 325ic coupe? I'm trying to figure out if I bought a bad ECU, the ECU is non-compatible, or the tech was wrong. The BMW, Bosch, and Motronic numbers are different and it's going from a auto sedan to a 5-spd coupe convertible. Should the replacement work?
Thanx in advance
Old 09-24-2009, 07:17 PM
E30 F34R's Avatar
E30 F34R E30 F34R is offline
Metric Mechanic
Mein Auto: Polly(My '87 track ****)
Thanx in advance
Autos have a second computer for the auto.
~ Puch Cafe. ~ Instagram, follow me. ~ Do business? feedback ~ Check out my company ~
Originally Posted by MP330 View Post
they looks the same as other coilovers on ebay.....megan,cxracing,bc....one factory,many labels..
guru where are you?
