84 318i Not Running, Fuel Pump - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 08-30-2009, 02:21 PM
tock172 tock172 is offline
Mein Auto: 2012 135i
Looking at picking up an 84 318i on the cheap locally. The owner says the fuel pump went, and it won't run anymore.
I am just looking for some general answers here, so I will make it quick. Does this sound normal for 200k? Or are there more major things wrong here that I should worry about?
Old 09-23-2009, 01:57 AM
elm3lem_youssef elm3lem_youssef is offline
Mein Auto: E30 Facelift
Check the fuel pump as owner said i had the same problem
Old 09-23-2009, 02:03 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
for some reason i found that a faulty sender unit to the gauge cluster was the cause of my fuel pump not working in my POS car, so have a look at that if you find your pump to be fine
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
