E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
#26
Cobalt now has a listing - D946 fronts - as The Hack pointed out; size is almost identical to the D394 on the non comp e46 M3. I'm not looking for a track only pad and I only drive the car in warmer months. My connection at Federal Mogul on the Ferodo DS 2500's has not come through? Price may swing me over to the new StopTech Street Performance pads. I have the winter to decide.
2006 Z4MC - #LL93158 - SuperSprint Race - OE STB - Dave Z Modified CDV - Ground Control Coil Overs - Stoptech lines - Stoptech Pads - RE Clutch Stop - RE Transmission Mounts - LeatherZ M Shift Boot - ZHP Shift Knob |
#27
2: Bedding is that initial even transfer of the pad to the rotor that he apparently mentioned... I think there was a misunderstanding.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No. ![]() TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers |
#28
-Actually pads work by both abrasive and adherent friction, at different points depending on the temperature range that they are designed for at what they are experiencing at any given moment.
#29
You know what I meant, they aren't meant to stop using abrasive friction, all it's there for is to add heat to get into their operating range. That's like saying your motor is run by the starter, sure it's run by it for a few seconds, but it's meant to run on gas.
#30
![]() Brakes used outside of their operating range still function fairly well (IE: HT-14s at street temps, or street pads at track temps), but have negative side effects and don't reach optimum performance. Unlike a car engine being driven by a starter motor, which does not come close to achieving the typical performance of the engine. Try again with your metaphor... |
#31
I called Cobalt again today to clarify and got a better (or more complete) answer. They say you dont need to "bed" in the XR pads when using them with a new rotor or a rotor that was using XRs before. These pads are high carbon and the technology they use (resins etc) allow for pads to be used right out of the box.
Now if the XRs are used with a rotor that had another pads' transfer layer on it, then you need to do some bedding to remove the other transfer layer and put this one on. For this they recommend about 3-4 laps and then about a 15-30 minute cool down time. After that, you should be good to go.
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW V3s|OEM Strut Brace|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|SSR GT2-H 19x8.5/19x10|Potenza RE-11s Texas Mile (March, 2010): 155.4 mph |
#32
Anyone try Cool Carbon yet? The Hack has them on the rear - looks like a good all purpose pad...
#33
I just think it's funny that any brake company would suggest that the other brake companies would use abrasive friction to stop.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
