Old 09-04-2009, 01:54 PM
98bmw528 98bmw528 is offline
Mein Auto: BMW 528i
Driver seat and Steering wheel problem!
I have a 98 bmw 528i and my driver's seat and steering wheel do not move in any direction. I try moving it and it just doesn't move. Still didn't work when I tried using the memory module.
Anyone have this similar problem?
How can this be fixed?
Thanks!!
Old 09-04-2009, 09:19 PM
cn90 cn90 is offline
Did you check the FUSE?
Old 09-04-2009, 10:40 PM
Mein Auto: BMW 528i
yep, checked all of them
Old 09-04-2009, 10:41 PM
Mein Auto: BMW 528i
i heard that the drivers seat has some kind of connection with/to the steering wheel?
Old 09-04-2009, 11:19 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
The steering wheel settings are set using the same memory as the seat, so they're on the same system.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 09-05-2009, 01:44 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Check the paneling around the seat controls. If it is loose or broken (very common issue) the connector may be unplugged or broken.
Old 09-05-2009, 02:15 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Yes...you did...but it doesn't appear that you read the thread thoroughly that James linked you to yesterday over on BimmerForums.
Did you try everything mentioned in the thread? I ask because I'm puzzled as to your response that you "heard" that the steering wheel and seats where linked...that linked thread on Bimmerforums explained how the seat control module behind the seat surround controls both the seat & steering wheel column...and if the harness is UNPLUGGED or pulled away from the module...it will stop the seat and column from operating. Which is the same thing noob and danny repeated here on BimmerFest.
Here's a link back to your thread on Bimmerforums...scroll down to James' reply and click on the links he gave and read through them thoroughly: http://forums.bimmerforums.com/forum....php?t=1302545
Good luck...and post back on BOTH forums what you found....there's no need to keep asking for suggestions if you don't look into what's already been given and report back your findings. You'll just end up getting the same information over & over.
PS: and if you click James' 2nd link...it gives you the whole thread and you'll see the the original poster fixed the problem by following the links and instructions on how to remove the seat surround and access the switch.
Q {BMW CCA Member #191509}
(SOLD)
Old 09-05-2009, 02:47 PM
Mr Majestik! Mr Majestik! is offline
Mein Auto: 2002 525i
Question 2002 525i adj. steering wheel and driver seat not working
Not tryin' to jack your post, but I have the same issue. My 2002 525i. The steering and seat adjustment went at the same time. Took it to a BMW mechanic and he mentioned a
'convenience module' needed to be replaced???
I hope the answers I'm reading here will apply to my car.
Old 09-05-2009, 03:34 PM
QSilver7's Avatar
Yes...click the link to the thread over on BimmerForums. The convenience exit feature is integrated into the large control module for the driver seat. If the plastic base around your seat is loose or broken on either the front or rear side...it's almost a dead give-a-way that it's the likely culprit if your seat & steering wheel column stops working and there are no other electrical gremlins like what you get with a failing ignition switch.
EDIT: here's the last part of the info I posted over on Bimmerforums...the OP posted back that he got the issue resolved...again, if you want to read that whole thread...click James" 2nd link in POST #2 at the link on BimmerForums.
The switch you need to check is the large black one that is on the other side of you seat cover (the plastic thing around the base of the seat). The electrical harness connects to that switch with one of the infamously over-engineered connectors where you have to press down on a small release button which allows you to move the lever that pushes the connector away from the switch (see image below):
When the seat cover breaks and hangs loose around the seat...the movement as you enter/exit out of the car tends to bear weight on this electrical harness and it breaks away from the switch (see image below):
..you can see how the switch breaks in almost the exact place...the image above & below are TWO different switches (above is from an e38/below is Bluebee's e39) but broke in the same place...
If my supossition is correct and you only removed the seat buttons and missed the actual electrical harness...then go to this link for a previous write-up on how to access the seat switch...from this write-up you will see what to do: http://forums.bimmerforums.com/forum...88&postcount=2
REPORT BACK YOUR FINDINGS.
(SOLD)
Old 09-06-2009, 10:00 AM
Cool
ty!
