Old 09-07-2009, 10:14 PM
semaj1 semaj1 is offline
Mein Auto: 1996 740il
96 740iL - Running hot
my 96 740il runs hot after runing for a couple miles, the temp guage moves over toward the red and then return to normal after a few seconds, this happens continuously every eight minutes or so. I've replaced the thermostat three times and just replaced the radiator. The upper hose to the radiator gets very hot while the lower hose remains cool, this causes the overflow tank to boil over. What could be my problem and a remedy? PLEASE HELP!
Last edited by semaj1; 09-07-2009 at 10:18 PM. Reason: added info. about temp guage.
Old 09-08-2009, 02:00 AM
Beemaboy Beemaboy is offline
Mein Auto: 320I, 525I and 740I
It sounds like you either have a huge airlock in the coolant passage or you have a split headgasket...
1987 E30 320I M20 Manual
1995 E34 525I M50TU Auto
1998 E38 740I M62 Steptronic
Old 09-08-2009, 11:52 AM
Ref: Running hot
Are there any other symptoms that would accompany a split head gasket? Would a bad water pump cause this?, because it seems that my coolant is not circulating. Where could I find a cooling system diagram for this vehicle?
Old 09-08-2009, 04:02 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
have you ever had the water pump replaced or maybe the previous owner done so? if not, they usually go out every 100000 miles or so, as far as what other owners have told me. supposedly due to the plastic empeller that the oem water pumps have. i'm told its best to go aftermarket with a steel or aluminium empeller.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 05-29-2010, 07:57 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
over heating
Check or change the fan viscouse coupling.
HTML code is Off
