My car has been showing signs of cooling issues for a while with a consistent "check coolant level" message. On frequent checks the coolant level was fine so I did not bother to add more coolant. I thought that it might have been the coolant level sensor.
A BMW shop did a cooling system test on it and said that it just needed more coolant. The message did not come back after that which was odd.
Today I was idling in heavy traffic with the AC blasting and the coolant temperature gauge started to climb and hit the red zone and flashed "coolant temperature" on the dash. I immediately blasted the heat until I got out of heavy traffic and the temperature reached back to close to normal operating temperature. Once traffic started moving it went back to normal operating temperature and I was able to turn the AC on again without any issues. Then the "check coolant level" message popped up again.
When I got home I noticed the coolant pouring out of the bottom of the coolant expansion tank over the pan at the bottom and on to the road. I checked a few threads here and waited for the car to cool down and the coolant stopped running out. I then parked on a sloped driveway facing up the slope and added more coolant. The tubes out of the rad were empty and I started the car.
The tubes started to fill up again so I ruled out water pump.
The expansion tank was not leaking so I ruled out cracked tank.
I left the car running and turned the AC on to flush out some of the air and it did and the temperature was stable for a while. One thing I noticed is the fan in front of the rad, behind the grille was not spinning. Then soon thereafter the temperature gauge started to rise again and coolant started bubbling over the top again. I shut the car off at this point.
Can anyone shed some light on what needs to be done here?
1. What can I do in the short term to at least drive it again tomorrow to the shop and ensure that I do not do any damage?
2. Once I got some coolant in the car (and purge as much air out of the system as I can without losing more coolant) can I drive it to work and then to the shop or should I go directly to the shop tomorrow? I will not need to use my AC in the morning and I drive all highway with little stop and go traffic to contend with. It is cool in the morning though.
3. What can I expect the shop to tell me? Is this going to break my wallet?
