Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 09-08-2009, 09:07 PM
Slaytanic_666 Slaytanic_666 is offline
Bavarian Moterwerks JAH!
Mein Auto: 1983 528E
Question Super eta???
I hear you can install the head from a 528i and make the the 528e a super eta??? Any truth to this? and if so what head is compatible with my 7/83 528e? Thanks in advance
http://www.youtube.com/watch?v=5Az_7U0-cK0
83/7 production Graphite Metallic 528e
Old 09-11-2009, 05:06 AM
nutgone nutgone is offline
Enthusiast
Send a message via Yahoo to nutgone
Mein Auto: e28 525e (eta)
You can swap head from M20 engines 2.3 or 2.5 litre (so that's e30 shape 323i or 325i, 523i or 525i). It's quite involved tho, you need to change the ECU & associated wiring, you also need to get the head complete with everything (both manifolds, air management & injectors etc). Check out wikipedia, can't remember where exactly but seem to remember it was somewhere around "BMW eta" or something like that. But in the end you end up with a higher performance 2.7litre engine, but bigger fuel bills. Also, don't forget, the eta concept was for an under-stressed engine, & it may be benificial to improve oil flow to the cam-shaft/top end, especially on the older engines (I believe hollow bolts can achieve this, but you'd have to check).
Old 09-11-2009, 05:13 AM
Enthusiast
I found it, try this link & you should be suitably informed
http://en.wikipedia.org/wiki/BMW_M20#M20B27
Scroll down to "Regular 2.7 Eta based" & you will find what you're looking for. (The whole thing makes good reading tho, & could give some useful ideas)
Old 09-14-2009, 11:11 PM
Red face Thanks
So many optioms on that page, and I have read it before, the table at the bottom states that my M20 from 83 has the weakest HP 121 sad eh? Cheers and thanks for the reminder of that page....Boooo Hooooo
HTML code is Off
