Does the 2006 E90 have an engine temperature reading? - Bimmerfest - BMW Forums
Old 09-09-2009, 08:17 AM
tiobueno tiobueno is offline
Mein Auto: 2006 BMW 325i
Does the 2006 E90 have an engine temperature reading? I can't find it any where on the onboard computer.
Old 09-09-2009, 08:41 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
It does not, it only has a warning light that comes on when temperatures are critically high.
Yeah, I don't like it either. The 335s get the temp gauge instead of the fuel consumption gauge, so do all coupes and I believe all wagons. Not sure about the verts.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 09-09-2009, 08:48 AM
Thanks CWinter! That is strange......At least there is an alarm if you are about to overheat!
Old 09-09-2009, 08:52 AM
cwinter's Avatar
Here comes trouble!
True, but what bothers me with the dummy light is that in most cases, you should have probably stopped a mile or so before that light went off to ensure you do not cause too much damage. A rising oil temp beyond normal is clearly an indicator that something is wrong.
I suppose their rationale is that if say you thermostat gets stuck closed, the car will overheat so quickly that both the gauge and light will alarm you about at the same time. That being said, the gauge is really only helpful if the overheating occurs slowly over a period of time or miles, giving you a chance to stop before the car overheats.
Anyway, I got over the fact that this is the first car I have that does not have a oil temp gauge. If at least it had a oil temp readout on the OBC!
Old 09-09-2009, 08:53 AM
BMW_GAL BMW_GAL is offline
Mein Auto: 2009 335i Coupe
We have both the temp gage and the fuel consumption gage, or is this something different that's being discussed?
Sig by Solidjake
2009 335i Coupe, Titanium Silver Metallic, Coral Red Dakota Leather, Gray Poplar trim, Premium package and Sports package with 19s.
Previously Owned: 2006 Audi A4 S-Line Quattro with all the belles and whistles and a B5 Imola Yellow Audi S4
Old 09-09-2009, 08:56 AM
cwinter's Avatar
Here comes trouble!
You have the temp gauge under your RPM tach and an instantaneous fuel consumption read out on your OBC digital display. You do not have both gauges, unless they scrapped the fuel gauge (how much fuel is left in the tank) on your car.
The 328 E90s get the fuel consumption (mpg) gauge under the RPM tach instead of the oil temp gauge. The fuel consumption gauge is helpful and I glance at it every once in a while but I would still prefer there to be a way to display engine oil temperature on the OBC. Clearly, the OBC is reading to oil temp in order to trigger the warning light if the car overheats, so why not give people a way to check what the last reading was?
Ah well...
Old 09-09-2009, 08:58 AM
Ah well...
So what's the gage on the right hand side (not the speedometer) but the other one with the picture of an (ohh...) is this the oil temp?
Sig by Solidjake
Old 09-09-2009, 09:02 AM
jwac's Avatar
jwac jwac is offline
Mein Auto: '14 335i 6MT
Like cwinter said, no there is no gauge or temp readout in the OBC. There are warnings of 2 severities. The first overheat warning is an amber icon in the OBC while the critical warning is red. If you have iDrive, you'll also get a message/description on the iDrive screen.
Keep in mind that on most cars, the temperature gauge isn't really accurate. They're sort of useful for seeing when the engine has reached operating temperature, but beyond that the gauge usually just sits in the middle unless the engine is too hot.
The newer 335i's and all coupes/verts come with a (real) oil temperature gauge in place of the instant mpg gauge.
2014 335i Sedan 6MT
Estoril Blue | Black leather | Dark Burl Walnut
M Sport | Premium | Driver Assistance Plus | Technology | Dynamic Handling | Cold Weather | 19" 403M Wheels | M Sport Brakes | Harman Kardon | Rear Window Shades | Auto High Beams
09.16.13 European Delivery
Past:
2011 335i Coupe 6MT (ED)
2010 135i Vert 6MT (ED)
2007 335i Coupe 6MT (ED)
2006 325i Sedan 6MT
Old 09-09-2009, 09:09 AM
jwac's Avatar
Just saw these latest posts... since almost all the temp gauges out there are dummies, they won't show a gradual increase. Once the temp has risen above a pre-set threshold the gauge will swing over the hot section. It then becomes a "real" gauge and will continue to move into the red. Engineers have generally abandoned real gauges because consumers too often think something is wrong with their car if the temp, etc is "different than it usually is".
Theoretically the amber warning on the E90 should come on well before a critical period is reached.
2014 335i Sedan 6MT
Past:
2006 325i Sedan 6MT
Old 09-09-2009, 09:11 AM
cwinter's Avatar
Here comes trouble!
Good info, thanks!
I am glad they have a two stage warning process, I vaguely remember reading that in the manual.
Old 09-09-2009, 09:15 AM
cwinter's Avatar
Here comes trouble!
On all coupes and 335s you show the amount of fuel left in the gas tank on the left and the engine oil temperature on the right.
On the E90 328s you show the fuel left in the gas tank on the left and the instantaneous fuel consumption in miles per gallon on the right.
My 328i looks like this below (even though these gauges are out of an X5 I believe)
Your 335 looks like this. Notice the different gauge under the RPM tach.
Old 09-09-2009, 09:18 AM
Huh, never did realize how differen't they are. SO...335s have the oil temp gage then!!
Sig by Solidjake
Old 09-09-2009, 09:20 AM
cwinter's Avatar
Here comes trouble!
They are really not that different, the first picture is out of an X5 but it uses the same layout as the 328 E90s.
Anyhoo....this reminds me of tutoring algebra...I saw the light bulb pop up over your head.
Old 09-09-2009, 09:21 AM
Temp Gage 101
Phew...the hamster is back to running again, he just took a little break
So in response to the OPs question, not sure about 2006, but the 2009's do have an engine temperature reading
Sig by Solidjake
Old 09-09-2009, 10:15 AM
cwinter's Avatar
Here comes trouble!
Only if it's a coupe (there was none in 06, right?) or a 335 (there was none in O6). Stop confusing the fella!
There is no gauge on the 2006 325i period.
Old 09-09-2009, 10:20 AM
FLA 335 FLA 335 is offline
Send a message via AIM to FLA 335
Mein Auto: 2009 335i Sedan
lol.
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / Tischer First Aid Kit w\Triangle / Tischer Hood Pad
Old 09-09-2009, 10:30 AM
Vamshi Vamshi is offline
Vamshi
Mein Auto: 325i JetB/prem/sports/xen
yep!.....there is no oil temp gauge in 2006 325i......it has mpg.....
Old 09-09-2009, 10:33 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Both the coolant temperature and the oil temperature can be accessed by the on-board computer if you put the dash into diagnostic mode.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 09-09-2009, 10:37 AM
Calif65GM's Avatar
Calif65GM Calif65GM is offline
Mein Auto: E93-35 May08 ED
+1; no MY 06s e9x have an oil temp gauge
E93-35 ED 5/2/08 completed 16:20.
Montego/Jade Gray, Gray Poplar trim, Step w/Paddles, PP, SP, CA, Heated Seats & iPod. 24-mth lease with 19,250 mi/yr. Re-delivery 6/20/08 (1st day of summer); 7-wks total.
[/SIZE]
De-badged 330xi/Mystic Blue/Gray Leather/Alumin. trim/Auto/PP/SP/CA/Fold-down rear seat/alarm. ED date 11/14/05 and redelivery completed 1/14/06. Sold to Carmax 6/7/08 w/ 50,650 miles on the clock
mapezzul's Avatar
mapezzul mapezzul is offline
Special Agent
Mein Auto: Depends on the day!
The reason there is no temp gauge on the N52 engine is that it has several different operating temperature ranges- it is hard to explain but the thermostat and ecu work together to have the vehicle in a certain range, for start up, performance, efficiency and a few added cycles for variation in fuel and altitude.
The fluctuation of a true gauge would make the driver think there was a problem when in fact there wasn't- since most never open the manual to learn such things.
These temp ranges help BMW get the most efficiency, performance and lower emissions.
These modern engines are amazing.
-M
2008 ///M3 Sedan. Jerez Black, Black Novillo/Sycamore, ZTP, ZPP, ZCW, iPod, Enhanced Premium Sound, 6 spd.
2008 328Xi ED 9/25/08 (Hers) White, Beige, ZCW, Xenon, Step.
2007 530XIT ED 3/22/07. Mystic Blue, Auburn, 6 spd Manual, ZPP, ZSP, ZCW, Nav, PDC.
2006 325i ED 8/29/05: Retired
Old 09-09-2009, 12:36 PM
AzNMpower32's Avatar
Tar Heel Faithful
Like others said, the coolant temp will vary and is controlled by the DME. Most coolant gauges thesedays are buffered anyways for reasons mentioned above.
The only way to see the coolant temp is thru the diagnostic menu:
Nominal temperatures range from 92-107C.
Old 09-09-2009, 01:50 PM
invariant's Avatar
invariant invariant is offline
Mein Auto: 2008 335i
How do you access the diagnostic menu?
2008 E90 335i 6MT + SSK + CDV-delete / ZSP / aluminum / black leather / Conti DW + compact spare / integrated portable nav plus
2005 E83 X3 Auto
Old 09-09-2009, 02:12 PM
Tar Heel Faithful
http://www.bimmerfest.com/wiki/index...uter_Functions
Since the newer BMWs don't use a key, one would push/hold the trip reset button while inserting the keyfob. The lock code for the E9x is the sum of the last 5 digits of the VIN.
Old 09-09-2009, 02:36 PM
Lenaxia Lenaxia is offline
Mein Auto: 2006 330xi
I am thinking about installing these into my '06 330xi.
http://www.e90post.com/forums/showthread.php?t=295605
It fits right into the ashtray and they should have a color that matches your interior.
Old 09-09-2009, 02:39 PM
invariant's Avatar
So, once unlocked, will it lock again after you turn the engine off, or will it stay unlocked? I mean, is there any way to keep water temperature as a constant item on the menu list?
2005 E83 X3 Auto
