Old 09-04-2003, 09:32 PM
TxnBluDvl TxnBluDvl is offline
Mein Auto: 98 M Roadster
Center gauge blank panel part number?
In my 98 M roadster, there is a black circular plastic panel that covers where the voltmeter was installed in subsequent models.
Does anyone know if this part has a part number and if it can be ordered?
I have no real use for a voltmeter, but I plan to install something on the black circular plastic filler panel. I want to make sure that I can get a replacement in the event I screw it up in a bad way.
Thanks in advance for any help y'all can provide.
Old 09-06-2003, 12:30 PM
viper501's Avatar
viper501 viper501 is offline
lost and confused ...
Mein Auto: 911 gone. Coming soon...
Depending on how much of a hurry you are in, I'm going to put an oil pressure gauge in mine one of these days ( have to finish house projects first). Once I do, it'll be free for you.
Old 09-06-2003, 03:23 PM
Ron Stygar's Avatar
19,585 Miles
Not that I could find.
Old 09-08-2003, 02:47 PM
Viper501, that would be GREATLY appreciated! I'll send you a PM/e-mail.
Thanks,
Conway
Old 09-08-2003, 02:48 PM
Ron,
Thanks for taking a look for me! It's probably like those one-off parts they have for the M coupe, with no P/N. That middle piece intrigues me. Do you happen to know what is it for/does it do?
Old 09-08-2003, 03:54 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
We have a couple of HVAC rings in stock if anyone needs one. We can do better than $59.25 each obviously.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 09-08-2003, 04:00 PM
viper501's Avatar
Conway,
No problemo. You could speed things along by telling me how / where I tap into the oil pressure and what I need to do it. A web site with instructions / how-to would also be great. I'm more than a little intimidated by the thought of killing my engine by making stupid mistake on that side.
Old 09-08-2003, 05:00 PM
Randy Forbes's Avatar
Investigative Tinkerer
Conway,
What version of the M Rdstr do you have (98-00 or 01-02)?
Either version will use a port on the oil filter housing. The S-54 has an unused port with a plug in it and the earlier S-52 has all the ports being occupied. I have made a few adapters to gang the oil pressure sending unit with the oem temperature sensor to get past this problem. You would remove the oem sensor and mount the adapter block with a Banjo Bolt. the oem sensor and the new pressure transducer would both screw into the block.
Randy Forbes
2001///M Rdstr Steel Gray
Old 09-08-2003, 06:56 PM
Old 09-08-2003, 07:06 PM
Ron Stygar's Avatar
19,585 Miles
Conway,
If your just adding oil pressure all you need is the VDO angle adapter and the VDO oil pressure sensor with the idiot light contact. You already have the oil temperature gauge. Maddux sells this stuff. He aslo sells the chrome ringed gauge that you need.
http://www.unofficialbmw.com/images/oilpressure7.jpg
http://www.unofficialbmw.com/images/oilpressure8.jpg
Old 09-08-2003, 07:52 PM
I thought all the ports were taken...
... guess I could go look at the car in the garage!
Does the pressure sending unit with the oil light contact do away with an oem switch?
Randy Forbes
Old 09-08-2003, 08:06 PM
Ron Stygar's Avatar
19,585 Miles
Yes, using the VDO angle adapter.
PS When you had your valves done did you notice if your coils were black (Bremi) or silver (Borsch).
Old 09-08-2003, 08:40 PM
Black.
What's the difference?
Randy Forbes
Old 09-08-2003, 08:51 PM
Ron Stygar's Avatar
19,585 Miles
Black.
Remember the problem Drex had and they replaced all of the coils.
There is a service bulletin on this SI B 12 08 03 dated 6/03.
Bremi coils prior to production week 42/02 have internal insulation deterioration resulting in reduced ignition firing power. Bosch coils are OK.
Old 09-08-2003, 09:02 PM
Thanks, and right on time...
Car is going in tomorrow for another SES light.
What do you bet it's the post cat 02 sensor cyl 123 again?
Randy Forbes
