Old 09-17-2009, 08:11 AM
adejr05 adejr05 is offline
Mein Auto: 745i
02 745i - Smoke
I need help my 2002 745i smokes, when it idles and I take off blue smoke, it misses really bad and sometimes cut off when i pull the dipstick out so took it to dealer they are trying to tell me it is bad gas oh yeah by the way getting code for cat converter or o2 sensor on bank 1 and 2 hes trying to tell me that running it low in gas will make it do it to so they cut the check engine light off told me to put 93 octane in and drive see if it clear up but what do you know still the same thing been looking for the post of everyone else is having the problem with the osv but i can only find the one for 1997 model, cant find the one for the 2002-2008 could someone please point me in the right direction. Sorry for the problems but i need to prove this dealer wrong because he thinks im stupid thanks in advance
Old 09-17-2009, 08:48 AM
07B7's Avatar
07B7 07B7 is offline
7 Addict.
Mein Auto: Alpina B7
blue smoke means burning oil. burning fuel is black smoke.
2012 X6 ///M Sapphire Black
2007 Alpina B7 - Alpina Blau II/Creme (Sold)
2004 X5 4.4i - Toledo Blue/Grey (Sold)
1994 300ZX TT - Black/Black
Old 09-17-2009, 08:53 AM
Mein Auto: 745i
thats what i was trying to tell the guy he thinks im stupid do the 2002 have the osv valve
Old 09-17-2009, 11:59 AM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
If its your cats and you have less then 80k miles your within range of the federal emmisons warranty on it and it will be replaced by bmw for free. I would press them even if i had 82 on it. Good luck.
Old 09-17-2009, 03:03 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Part #13 on this diagram. OSV is the term on E38's. On E65/E66's I believe they are normally called CCV's (crank case vent or something to that effect). Also, they learned from the E38...the ones on these are really easy to get to and repair / replace.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 09-17-2009, 07:51 PM
allaboutdaz allaboutdaz is offline
Send a message via AIM to allaboutdaz Send a message via Yahoo to allaboutdaz
Mein Auto: 745
i waas looking into this as well
a lot of people say that the problem is the crank case vent valve or something like that
but i would also like to know if that is the problem
Old 09-17-2009, 07:57 PM
bigram67 bigram67 is offline
bigram67
Mein Auto: 2002 bmw 745i
Has anyone tried fixing the weep hole leak yet with removing the engine
Old 09-18-2009, 08:20 AM
Mein Auto: 745i
i bought the crankcase valve today getting ready to put it in ill keep yall posted
Old 09-18-2009, 01:04 PM
Mein Auto: 745i
crankcase valve did not fix my problem
Old 04-05-2010, 09:44 PM
Mein Auto: 745
was your issue ever fixed? and what was the problem
i am still trying to find out whats wrong with my car and there are so many things that can cause the fault codes and have similar symptoms
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 04-06-2010, 05:39 PM
m50b25 m50b25 is offline
Account closed at users request
Mein Auto: BMW 745
change your valve stem seals 40$*2 kits
expensive valve job~500$
Old 04-29-2011, 10:31 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
I seem to have the same problem. When I first take off in the morning after letting the car run for 15 mins blue smoke come out of the pipe??? Is that My CCV Valve and the valve stem seals?
Old 06-13-2011, 08:06 PM
bmw745iman bmw745iman is offline
Mein Auto: BMW 745I
Guys did yall find any solution to the blue smoke im at 205000 miles and im starting to get some idle smoke. Could it be time for rebuild, how long to do seals?
Old 06-15-2011, 08:04 AM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
My blue smoke after idle issue, was cured after replacing the CCV's. (200 dollars by an indy shop).
Old 06-18-2011, 02:33 PM
Bsjones745ife13 Bsjones745ife13 is offline
Mein Auto: 2002 745i
You should go to your mechanic and get a refund...No way this cost $200. Changing these out literally takes 15 mins tops and I'm not the most mechnical. Smoke seems to have gotten better also after I changed mine out.
Old 06-18-2011, 10:27 PM
roadfrog's Avatar
Oops, that should have said 141 dollars. 60 dollars of that bill was for other parts and transmission diagnosis. Each ccv was 45 dollars....plus labor
Old 06-30-2011, 08:35 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Wow really? The e46 must be more complicated in that regard
mujjuman
Old 11-22-2011, 03:37 PM
Rookie2008's Avatar
So the blue smoke issue may be the CCV? I the CCV also reference as the Crankcase Vent Valve? Part number please guys if you have it. Thanks.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 01-28-2012, 12:54 PM
lee28me lee28me is offline
Mein Auto: 02,745i
is ur issue fixed
I bought a used 745i bmw 02 as is the second day after i bought it it started smoking white smoke from the tail pipe and check engine light come on. Coolant light also came on said coolant was low. You guys say blue smoke from your tail light. mines have only been white as far as i know. every two days i had to put coolant in it. i only driving it a week in the two months I had it. the diagnostic run from an independant bimmer mechanic had 40 engine codes. Do you think if I replaced the ccv's and find out where the coolant is leaking will fix the problem,before changing the HG valves? I'm clueless on cars. just want my dream car fixed.
Old 01-28-2012, 01:37 PM
B7Heaven B7Heaven is offline
If you are losing coolant and it is not leaking outside the engine, then it is leaking inside the engine. It can only go into the crankcase/oil or into combustion in which will make smoke out your pipe with a distinct smell. You need to get this car diagnosed properly right away. Don't waste money on trying to replace CCV, ect. With coolant likely entering combustion you are looking at head gasket, cracked head, cracked block.
Old 01-28-2012, 02:24 PM
Tarek307's Avatar
Tarek307 Tarek307 is offline
Send a message via MSN to Tarek307
Mein Auto: 911 Carrera S
its 8 years 80k, he's past that since its an 02
Old 01-28-2012, 03:00 PM
Rookie2008's Avatar
Originally Posted by b7heaven View Post
if you are losing coolant and it is not leaking outside the engine, then it is leaking inside the engine. It can only go into the crankcase/oil or into combustion in which will make smoke out your pipe with a distinct smell. You need to get this car diagnosed properly right away. Don't waste money on trying to replace ccv, ect. With coolant likely entering combustion you are looking at head gasket, cracked head, cracked block.
+1
Old 01-28-2012, 03:26 PM
Mein Auto: 02,745i
02 smoke
Ok thanks,for the advice. the dealer put it on consignment. i hate selling that car if somethings that seriously wrong with it. I think that runs about 4000 and up.
Old 02-05-2012, 07:02 AM
Looks like the person who sold you the 7 didn't disclose this info. These issues don't happen overnight especially with the smoke. The dealer or person had to know. I would sell it if I were you and get a different 7 or different car all together. You will be throwing money at it left and right...Good luck
Old 02-05-2012, 12:44 PM
Mein Auto: 02,745i
the dealer claims the vehicle never had these problems before I bought it. It all occured in the 1 day after I purchased it.
osv, smoke
