Old 09-18-2009, 07:58 AM
adejr05 adejr05 is offline
Mein Auto: 745i
replaced ccv valve
replaced ccv valve and it did not fix my blue smoke what else could it be
Old 09-18-2009, 09:05 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
How many miles do you have?
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 09-18-2009, 09:41 AM
Mein Auto: 745i
115,000
Old 09-18-2009, 11:14 AM
Master Tinkerer
Did you replace both CCV valves or just one? You really shouldn't have blown rings this early on with this engine...maybe head gasket? Does the blue smoke pulse like it might be on one or two cylinders, or come through on what seems like every cylinder's firing? How fast are you losing oil? Losing any coolant? Any oil in the coolant? Any coolant in the oil?
Old 09-18-2009, 11:59 AM
Mein Auto: 745i
i am not sure how much oil its using ive had it bout 2 months about 3000 miles ive put 2 quarts in it steady smoke when i sit and idle and yes i did replace both
Old 09-18-2009, 12:02 PM
Ryan M Ryan M is offline
Mein Auto: .
Get a compression test done. If a cylinder is found to be below spec do a leakdown test. That'll pretty much pinpoint the problem.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 09-18-2009, 12:26 PM
Mein Auto: 745i
correct me if im wrong but would it smoke all the time if it was a ring
Old 09-18-2009, 12:44 PM
Mein Auto: .
Usually, yes. Valve seals will produce smoke either upon startup and disappears shortly after, or smoke upon deceleration because vacuum is at it's highest and oil is drawn through the seals. It wouldn't be a head gasket or burning coolant because the smoke would be white.
Old 09-18-2009, 04:22 PM
sleeper118 sleeper118 is offline
Mein Auto: 2005 Bmw 745I
I had the same problem. It was the intake manifold gasket. All repairs including new plugs, oil, plug seals and labor was about 2500 and 2-3 days. Best of luck.
Old 09-18-2009, 04:24 PM
Of course cash is king. I think i paid less than 2k
Old 09-18-2009, 04:53 PM
Mein Auto: 745i
what exactly was yours doing before you got it fixed
Old 09-19-2009, 05:57 AM
I was getting small clouds of smoke when i would start it after work, and only after..So I took it in and was told it was a sensor, (phew) but the cpu would have to be flashed after instal and only the dealer could do it... So the dealers hours suck so i have to wait. One day on the way home from work I floored it and a HUGE cloud of smoke came out and warnings came on...engine, exhaust... so it took it to the dealer and after a days of waiting and test after testest I took it from the dealer with nothing fix. The wanted to a compreshion test ($700) lol. But the car was misfireing, and lot of build up on my spark plugs( so some oil was bing suck into the combushion chamber). So took it somewhere else and it was the gasket. Which is a common problem with this car from what I read. But since the repair no problems.
Old 09-19-2009, 06:04 AM
Master Tinkerer
Can anyone provide a link from realoem.com for the gasket that was replaced?
Old 09-19-2009, 06:45 AM
http://www.realoem.com/bmw/showparts...77&hg=11&fg=40
