Engine Oil Pressure light please help!! (and cooling system) - Bimmerfest - BMW Forums
Old 09-19-2009, 08:00 PM
mrpumpk1n mrpumpk1n is offline
Mein Auto: 540i 1997
Hello again :-). I am having another problem with my car. When i start my car nowadays it seems to run just fine. However, after driving the car for a while (letting it heat up), once the car comes to a stop the red engine oil light starts to flicker on. If i press the gas, it goes away. If i keep coming to a stop, the light eventually becomes solid and the sign "STOP ENGINE OIL PRESSURE" or something similar comes on. Ive checked if i have engine oil in the car using the dipstick before and after each of these drives. (and obviously im having to limit my driving to very little, pretty much to garages and back). i took it to a few places and no one is wanting to fully diagnose it as of yet, but they keep saying its either the "oil pressure switch?" or the "oil pump". i am hoping its just the switch causing this as its the cheaper of the fixes (im assuming)? What do you think it might be? i dont hear any sounds when this happens, however i do feel some vibrations very slightly when this happens and most probably its in my mind because no one else in my car feels it nor do the mechanics. If it is the oil pump, how much do you think it would cost to replace it (in terms of labor fee). i heard from someone that its relatively simple to change the oil pump in these cars as all they have to do is take off the oil pan and the pump is accessible easily, is this true? Could it also be something else?
On a side note, for some reason it feels to me as if the car is heating up a bit too much. The engine temperature meter is always half way between cold and hot (when the car is warmed up) and never goes above that, but it feels to me as if its radiating a lot of heat compared to other cars ive seen. Is this normal to the e39? Sometimes when i drive it and the car warms up, it sounds like a truck (im assuming the sound is coming from the fan).
My Car:
1997 540i
V8 EFI DOHC
using 10w30 mobil 1 engine oil
Old 09-19-2009, 08:19 PM
cn90 cn90 is offline
Sometimes the Plastic Oil Filter CAP misses a few parts at the very tip causing this Oil Pressure Light.
Remove your Plastic Oil Filter CAP and compares against a known good picture.
I changed my Plastic Oil Filter CAP at 100K because it cracked when I opened it.
But at 12 yrs and ? 120K, replace it anyway, it is Plastic!
$28 at dealer or online.
Old 09-19-2009, 11:30 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
The only way to check this out is to connect an oil pressure gauge at the oil filter, and compare actual pressure with the specs.
Old 09-19-2009, 11:40 PM
Ryan M Ryan M is offline
Mein Auto: .
^^^^Correct. The oil pressure switch is removed, and the pressure guage is installed in its place. The specs for oil pressure for the 540i are:
Oil pressure at idle speed with engine at operating temperature: minimum .5 bar
Regulated Pressure: 4.5 bar
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 09-20-2009, 07:38 AM
if it is lets say the oil pump, how hard is it to replace? is it labor intensive? or is it a [relatively] simple job of lets say just dropping the oil pan without having to remove anything else, and changing the oil pump?
Old 09-20-2009, 07:56 AM
Oil Pump lasts the life of the engine.
Replacing the oil pump is a labor-intensive job.
Go and look for more obvious causes (Bad Oil Filter Cap as I mentioned!).
Old 09-20-2009, 08:02 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Do a search for "loose oil pump bolts" . If you don't get any hits...go to www.e38.org or www.e38.org/e39 and do a page search [Ctrl+F] and type "oil pump" as your search words...there was lots discussions about this in years past about the early m62 engines and loose oil pump bolts which would cause the warning lights you've been getting.
Please don't wait to check if your bolts are loose...it could be catastrophic if one or more of the bolts drop out and get caught in the chain...or the pump drops.
There are THREE bolts that support the oil pump...two are easy to see because there out front (see pics below)...and there's a 3rd bolt that is behind the pump which is easy to miss:
two front bolts are circled in yellow: images by John (Oxford Files)
and here's the 3rd bolt located behind the pump
Q {BMW CCA Member #191509}
(SOLD)
Old 09-20-2009, 08:07 AM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Absolutely!
Old 09-20-2009, 08:08 AM
poolman poolman is offline
Mein Auto: 525i station wagon
I thought it was a snap to remove the oil pan on the 540 models--it's a major under taking on the i6 cars.
If memory serve's there was some problems with oil pressure sensors--best way is to go through all the motions--replace the cap as cn90 stated--check the pressure with a mechinical gauge and then if all else
fails--the oil pump bolts--I wouldn't drive this thing far --if at all until the problem is settled
Old 09-20-2009, 05:27 PM
franka franka is offline
Mein Auto: E39 540i Sport
What weight of oil are you running and is it always on the dip stick at the correct line?
I too say forget the oil pump. The light comes on when stopping because the oil goes to the front. if its doing that on easy stops you probably need to add 1 or 2 qrts more oil.
Add two quarts and call me in the morning.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 09-21-2009, 11:36 PM
M///Chook's Avatar
M///Chook M///Chook is offline
I am the Wumpus
Mein Auto: 1996 E39 535i V8 sedan
^ I realise that disagreeing with Franka is a major thing in these forums, but I would have to say that if the light comes on when he pulls to a stop, it may be because the engine rpm goes down to idle (550rpm or whatever the idle speed is supposed to be) and oil pressure goes down in proportion because the pump is driven from the engine crankshaft assembly.
At idle, the oil pressure should be around 0.5 bar (or 7.4 psi) and at high engine rpm it should regulate at 60-65 psi.
if the light comes on at idle speed, this may be because at idle there is below 7.4 psi because of some problem or inefficiency with the oil pump. Once engine speed increases, pressure will always increase, and thus the light will go off.
I dont mean to disagree with you Franka, and I have a great deal of respect for your answers in these forums, but thats my alternate theory to what might be happening. Since the oil in the sump will more or less level out after say 10 seconds of stoplight idling.
No disrespect intended
1996 Carbon black/black BMW E39 3.5L M62 V8 535i -Australia Delivery-only model.
And this months "mods" are:
  • leaky power steering reservoir
  • Cracked windscreen
View my album- http://www.bimmerfest.com/forums/album.php?u=158428
Old 11-06-2009, 03:36 PM
lude_bimmer98 lude_bimmer98 is offline
Send a message via AIM to lude_bimmer98 Send a message via MSN to lude_bimmer98 Send a message via Yahoo to lude_bimmer98
Mein Auto: 540 i
at the op: I am having the same problem with my car as well. I am not sure what is causing the egine pressure light to come on. If I figure it out I will let you know. Meanwhile, If you figure it out before I do let me know.
[/SIGPIC]
On s'enbeurre les fesses royalement!
Old 11-06-2009, 04:32 PM
atrovarious's Avatar
atrovarious atrovarious is offline
Mein Auto: Black 1997 528i
That too is what I was thinking as well... however the pump could be pumping just fine but the only time the loss in pressure is noted is when it is pumping at idle.... my experience with bad pumps has been all or nothing however which leads me to believe that this may not be the culprit in this case.
Old 11-06-2009, 08:44 PM
lude, what oil are you using? this is a long shot, but i dont think the pump is my problem either. i was doing some research and i think i may just be using the wrong grade oil. Im using mobil 1 10w30 synthetic, i was looking into it and its not ACE-93 (or something liek that) nor LL-01 approved. according to some sites, these oils thin out wayy to much when it gets hot or at normal operating temperature. im going to try changing my oil with bmw oil (at the stealership) and see if it works out. if not, then im going to go look for a higher paying job lol and change the oil pump. (ive read at some forums that people had problems similar to this and realized their oil wasnt ll-01 approved and changed oil and the problem went away)
Old 11-06-2009, 09:37 PM
Why don't you do a simple thing:
- Get an OEM Oil Filter and change it at home, it takes a few minutes with the 36-mm socket.
- When tightening the cap, just snug with 2 fingers on the ratchet, no need to go to 25 Nm as the book says.
Your Oil Filter may be partially clogged.
Old 11-07-2009, 07:04 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I don't think it'll thin out too much; 30 weight is 30 weight, unless it doesn't comply with basic standards.
However, in NYC, 10w is a bit heavy for cold starts. It doesn't matter what the "spread" is with synthetics, as there's no "stretching" polymers in true synthetics to break down. 5w30 BMW oil is fine; I use Mobil1 0w40 myself due to limitations in oil supply (I'm not going to pay $13/qt for Amsoil 5w30, sorry….not to mention the special order I'd need to place with the unreliable store that sells it.)
You can buy the BMW oil and change it yourself, saving you a huge cost. Using a BMW OEM filter (you could buy it from EACTuning or another board sponsor) is very important, with any oil. I'd go with a LL-01 approved oil if there's a problem, before putting in BMW's unobtanium-enhanced oil.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 11-07-2009, 11:03 AM
Mein Auto: 540 i
I used mobile 1 5w-30. And for my heating problem , I figure out what was the issue. My heater control valve went bad. The cheapest I found it was 220. Bmw priced me 495 bucks. Sad Story!
[/SIGPIC]
Old 11-07-2009, 12:58 PM
So what is so special about LL-01 or whatever the code is?
Maybe some of the oil specialists we have on this forum can answer that so we can all understand.
Frank
540/6
Old 11-21-2009, 03:53 PM
UPDATE:
I got my oil change done (since it has been 6 months anyways). To try to be safe, i went to an indie BMW shop and put in ll-98 approved A3 oil (castrol 5w40). So it didnt solve any problems, although with the thicker oil (castrol 5w40) its taking a little longer for the oil light to come on.
Lude, how long did you have your oil light problem for? do you still drive your car around? did you find a solution? .. and is your engine still intact?\\
Do you think a bad thermostat is making the car slightly overheat without me knowing (since the meter isnt going past half way) and the oil thinning out because of excess heat and losing oil pressure?
the shop also said that my timing cover gasket might be leaking... is that going to be very expensive to fix? (they quoted me $800 and i said il come back... i think they are ripping me of?)
Old 11-21-2009, 06:14 PM
Now you have changed the Oil and Oil Filter and the problem persists.
Then my best guess is defective Oil Pressure Switch.
Very easy to replace for V8 engine:
Up to 09/1997: 12611731499
http://www.realoem.com/bmw/showparts...11&fg=30&hl=38
http://www.rmeuropean.com/Part-Numbe..._85647CDD.aspx
$19.00
From 09/1997 ---> 12617568480
$6.00
Old 11-21-2009, 10:00 PM
ive changed the oil pressure switch as well, the problem persisted. Here is the order of things, first i changed the oil pressure switch, and then i got my oil change with filter, nothing solved the issue. =( . the mechanics keep telling me to keep driving since the pressure problem is only at idle, but my knowlege is telling me that it wont be okay, low oil pressure is low oil pressure. what do you think?
Old 11-21-2009, 10:26 PM
tGunter tGunter is offline
Mein Auto: na
I'm sorry to hear this.
Oil pump bad.
Recommendation: R&R oil pump; rebuild engine. machine crank, bores, cylinders, replace piston rings.
Old 11-22-2009, 11:12 AM
eddiec eddiec is offline
Mein Auto: BMW E39 528i
mrpumpk1n,
After the switch, filter oil have been changed, did the garage actually measure the oil pressure as suggested by other posters?
Did you change the filterhousing ca as CN90 suggested?
If so, how far out of spec was it? (light should come on at 0.5bar or 7.4psi)
Is there any unusual mechanical noise, rumbling or vibration form the engine when under load?
You really need this infiormation as it will form the basis of your decision for the next step.
For what it's worth, I had similar problem a few years back on an E34, the pressure was approx 1 .5 psi below minimum value at warm idle. Couldn't afford to change the oil pump let alone rebuild the engine at that time so tried the "snake-oil" approach, admittedly more in hope than expectation.
A can of liqui moly visco plus (aka visco stabil) VI improver added to the engine oil increased warm idle pressure by 3psi. From memory cost about £2.00 ($3.50) per can. Kept the car for 16months after that, changed oil every 3k miles and added a can of viso-plus at each change. Low oil pressure light never came on again.
In this case I think the problem was wear in the pump causing the low pressure as there were no unusual bearing type noises from the engine.
I'm not proposing this as cure in your case nor am I suggesting you do this. Luckily it worked for me as, at the time, I had no other option. Normally I avoid snake-oil fixes as they generally don't work, but in this particular case - it did.
Addressing the cause of the problem is always the correct way to fix but before spending the money there are other considerations including overall condition of the car, how long you want to keep it, likely future maintenance expenditure etc.
With regard to the engine temperature, the only way to tell what's realy happening is to rig up a laptop or PDA connected to the OBD II port with some data logging software (PCM Scan or similar) and drive the car. Expect coolant and oil temperature to vary depending on how much load is on the engine.
Old 11-22-2009, 07:07 PM
I keep telling the shops to check my car's oil pressure using a mechanical gauge, but they keep telling me they cant. (wtf?). so i guess im gonna have to go ahead and do it myself (and i am illeterate under the hood). any advice? and about sounds and vibrations, there is no unusual engine noise, no rumbling, no tapping, nothing, and the engine runs very smooth, no vibrations.
Old 11-22-2009, 10:13 PM
Now you have changed the Oil P switch and the problem is still there. Possibilities:
1. Loose Oil Pump bolts as QSilver7 mentioned above.
This is actually not a bad fix for V8 because the oil pan can be dropped easily.
In contrast the 6-cylinder oil pan is a nightmare!
2. Wiring to the Oil P switch . Trace it back and see if it is broken. Sometimes wiring can be damaged by mice.
You live in NYC with millions of mice running around!
cooling system, engine oil pressure
