E60 (2004 - 2010)
Old 03-20-2012, 12:22 AM
jsarg419 jsarg419 is offline
Mein Auto: 2004 530i
s
Old 03-20-2012, 12:24 AM
2004 530i 155k Just now doing brakes for the first time
Old 03-20-2012, 04:32 AM
SomeHelp SomeHelp is offline
Mein Auto: Bus
2006 530i - 70K miles
Old 03-20-2012, 01:51 PM
luxcar luxcar is offline
Mein Auto: 2008 550i, HUD, SAT, L7
Do you ever apply brakes?
2008 550i M-Sport, SAT, HUD, Premium package, Comfort Access, L7, Comfort and Ventilated seats
2007 Acura MDX, Elite, Running boards, roof rack
Old 03-20-2012, 03:03 PM
bo0osted bo0osted is offline
Mein Auto: Monaco Blue 08 535i
He probably just drives cross country... all highway miles
Old 03-28-2012, 08:17 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z3 2.8L, 545i
156,564 miles today and still climbing
Old 03-29-2012, 03:09 PM
bimmerrg bimmerrg is offline
Mein Auto: 535i
41300.
2009 535i Black Saphire Metallic/Natural Brown/Prem pkg, Sport pkg, comfort access, Navigation, Sport Transmission with Shift Paddles, PDC, Heated Front Seats, iPod and USB Adaptor, Satellite Radio, BSW Stage 1 Speaker upgrade, JBL MS8 DSP, Technic Harness and BMW Individual co-axial center speaker ==> Superb Custom LOGIC 7, New Michelin Pilot Sport A/S tires! Route 66 Extended Warranty till 5+yrs:1/26/2018 or 100k miles.
Old 03-29-2012, 05:57 PM
LRMcNeil LRMcNeil is offline
Mein Auto: 530I
Miles on E60
My 2004 530i just crossed 140,000. Zero major issues. I AM holding my breath for the coolant system upgrades/replacements. Trying to get the $$ together with the initiative to actually DO something about it. I have had some minor things, but nothing major at all. To top it off, this car is a past chaueffeur driven executive car from the Jersey area - and has virtually every BMW option available on it! Lots of stuff to go bad - very little has. Had the passenger side seat weight sensor go out - BMW replaced on a 10 year warantee. Had some issues (posted on this site) with dynamic drive and active steering - which have turned out to be related to ever so slightly low fluid levels in the PS and brake system reservoirs.
Old 03-29-2012, 07:05 PM
pistonpopper pistonpopper is offline
Mein Auto: variety
2004 545 - 52 000 miles battery replaced as a precaution. Passenger side seat sensor. No other major repairs. I currently have an oil leak from the front passenger side area that only appears if the car sits for a while.
Old 05-12-2012, 02:01 PM
Avanes_G_545 Avanes_G_545 is offline
Send a message via AIM to Avanes_G_545
Mein Auto: 545i and 650i
2005 545i sport. Has about a 93k miles transmission replaced by warranty , gasket seal replaced also passenger wear sensor was replaced by warranty.
BMW 545i AT Sport. Black on Black
Old 05-19-2012, 09:22 PM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
2004 545i Sport - 82,300 (bought at 76K miles) and now running like a fine swiss watch.
But not always the case. Total of $14K in repairs under warranty (both BMW and extended warranty, mostly under previous owner). All the common oil leaks plus iDrive screen.
Engine removed at 75K miles to fix leaking lower timing case cover and dealer replaced gaskets on the entire top of engine, including the dreaded water pipe ($6K under warranty).
Previous owner followed 15K oil change intervals and likely burned up the gaskets (although the 4.4L V8 was not a stellar design to begin with).
I bought the car at 76K miles and since then she has receives nothing but TLC - engine oil, differential fluid, spark plugs, trans fluid drain and fill (trans pan and mechtronics sleeve was changed at 74K miles so trans filter is relatively new and power steering fluid was changed during engine removal at 75K).
Hope to drive it to 200K miles as I love it!
Name:	2004 545i Sport.jpg
Old 05-20-2012, 08:45 AM
kashrahman's Avatar
kashrahman kashrahman is offline
Mein Auto: 05 G35X; 09 335 vert
2004 E60 530i -- almost 90K miles when wife totalled it (2009). Mike Miller Old School maintenance. The only issues that come to mind are sunroof wound not close (happened during our ED, fixed) and around 60-70Kish the rear seat heater stopped working (loose connection, fixed). Otherwise bulletproof, and if she were still here would probably be pushing 130K+ miles . . .
2009 E60 535i -- just picked up CPO last month. has 32K miles. seems to have had the HPFP fixed twice. Hoping for another long-lasting, wonderful experience . . .
09 335 vert - ED Feb 09
06 325 vert - gone
05 G35x - winter
Old 05-20-2012, 08:49 PM
Hogie's Avatar
Hit 160,500 miles this weekend. One bugger I have had over the last few months is the windshield washer leaks from the reservoir at the pump grommet. Very slow drips. I have had the motor out about 5 times and two new grommets from BMW. I can't seen to get a good seal for some reason. I either need to get an oversize grommet or new tank I guess.
Old 05-21-2012, 06:25 AM
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2009 BMW 535i Sport
I've had my 2009 E60 535i since new ... now 39600 miles. Had the HPFP fail june 2010 and replaced. Then about a year or so later, it was again replaced via a recall, with an update version. Never had any problems with the first replacement, or the second ... that's probably why you car shows it being fixed twice.
BMW CCA Member
2009 535i Sport, Jet Black | Cobb Stage 1 | BMS Drop-in Filter | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus (no runflats)
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 05-21-2012, 08:40 AM
ankurg09 ankurg09 is offline
Mein Auto: BMW 530i
2006 530i - 84,000 miles, bought in 2008 with 35,000 miles
only problem - had to get battery changed and re-coded at stealership ,Paid $500
Old 09-22-2012, 03:49 AM
172,000 now. yes all high way miles live out in the sticks and its 30 miles to anywhere which is still nowhere. ha
Old 09-22-2012, 09:52 AM
SlackeSC SlackeSC is offline
170,000. Besides normal maintenance... Replaced A/C compressor. Oil gasket replaced due to leaks. About to replace suspension. Windshield washer fluid pump does not work. Front Bushings replaced twice.
2004 530i
Navi/Bluetooth/Logic7/iPodIntegration
20" MHT Custom Forged Edition 2 Piece LLC Black, 20x9 front, 20x10 rear.
Old 09-24-2012, 05:25 AM
Hogie's Avatar
170,000 miles this past Friday. I have one intermittent P0492 which I have a left upstream O2 sensor on order.
I have had all the common oil leaks and fixed. I am due for the lower control arm bushing changes ( second time) and new transmission pan/filter/fluid change. I have also started acquiring the coolant components, thermostat, waterpump and upper/lower hoses just to be proactive.
I change the oil every 10K miles now regardless of the iDrive ( normally 12 - 13K interval). I do have to put about 1 quart between intervals now which is very acceptable to me for 170K.
Old 09-24-2012, 12:38 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Around 10,000 miles on my 2010 530i
Old 09-24-2012, 08:32 PM
Kalil147 Kalil147 is offline
Mein Auto: BMW 545i
I have a 545i. Mine is a 05 with 72k miles. I need to replace the front bushings too. Did you replace the entire control arm or just the bushings? Did you need an alignment after replacing the bushings? I only ask because in about 6 months I will need front tires and dont know if I should wait to I replace my tires so I can do the alignment all at once, or replace the bushings now and worry about tires and alignment later.
Old 09-24-2012, 09:46 PM
countycop911 countycop911 is offline
Mein Auto: 2007 550i
Wow, I am extremely fortunate with low miles considering just purchased February this year. however it is encouraging to see all the high miles on these vehicles with few major problems.
Mine is:
2007 550i - Sport Package and lots of extras. Everthing but the night vision as I can tell.
Photo of Odometer attached.
Old 09-24-2012, 11:53 PM
fnknasty fnknasty is offline
funkdrummer
Mein Auto: 2008 528i premium sport
08 528 68386 miles... running strong..... battery cable recall.... make sure they use Grease when replacing cable ..! are else !! lifters replace for ticking noise .under warranty. one nasty looking machine ... replacing run flats .. any suggestions ?
Old 09-25-2012, 08:24 PM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Bimmer Craze
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
35,400 and love it
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |Front/Rear Cameras | Escort 9500ix |
Performance-Cobb Stg2+FMIC ST Agg | Injen Intake | BMS OCC | ER anodized FMIC |AR DP Catted |TIAL Q BOV | ER Charge pipe | Spacers (F 12mm/ R 18mm)
Cosmetic-32w Cree LED AE | Xenon HID Fog Bulbs | M5 trunk & Roof spoiler rear | XENON white Emblem LED BG Light | LED Side Marker | M5 bumper | Hamann LP | License & Interior LED lights| Tinted glass |
Old 09-26-2012, 05:03 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
Mine is:
Where did get such low miles car? and paid?
BMW CCA Member, Capital Chapter
Old 09-26-2012, 05:35 AM
bkun bkun is offline
Mein Auto: BMW 528xi - 2008
44500 miles. Tranny fault code appeared twice in the last two months. The msg disappears after I shutdown the car. Other than this no issues.
2008 BMW 528xi space gray, Premium, Cold Weather Package.
