535i pissing gas? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 09-22-2009, 07:40 AM
codymccann codymccann is offline
Mein Auto: 1986 535i
Exclamation 535i gas leaking.need help.
i have a 1986 535i and i thought one of my injector o-rings was bad but today i started her up and there is gas leaking out of under the 4th fuel injector. could this still be the o ring? there is A LOT of gas coming out while it is running. could it be a Idle Speed Regulator, or Fuel Pressure Regulator? need help. thanks.
Cody.
Old 09-22-2009, 12:05 PM
hugh1850's Avatar
hugh1850 hugh1850 is offline
Mein Auto: Jeep GC
Cody.
It might be the cold start valve (CSV). The CSV is fueled from the fuel rail at about the place you are having your proplem. The best way to see it is to remove the intake boot, along with the idle control valve and vacuum hose. The CSV sits in the intake manifold. It's pretty common for the fuel hose that runs off the fuel rail to the CSV to crack and leak.
Here's a great write-up talking about the issue:
http://www.mye28.com/viewtopic.php?t=17341
Part no. 9
1987 BMW 535i, 2016 X5, 2015 Jeep GC Overland
HTML code is Off
