Old 02-25-2006, 10:59 PM
caylan caylan is offline
Mein Auto: 2000 M Coupe
Torque wrench recommendation
I need a good reliable Torque wrench with decent measurements.
Can I get some recommendations please from you DIY pros please.
Thanks.
Old 02-25-2006, 11:11 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Used for what
What are you going to use the torque wrench for? Are you looking for a 3/8ths inch drive or a 1/2 inch drive? What foot/pound range are you looking for? How much do you want to spend?
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 02-25-2006, 11:26 PM
Things like oil drain plug or wheel lug nuts or even the vaunted IE bushings
I guess the bigger the range the better, so I don't have to get 2!
Best bang for the buck if possible.
Old 02-26-2006, 04:48 AM
MZ.368's Avatar
MZ.368 MZ.368 is offline
Crazy Coupe Lady
Send a message via AIM to MZ.368 Send a message via MSN to MZ.368 Send a message via Yahoo to MZ.368
Mein Auto: 99 Frankencoupe 09 mini S
Thanks.
I'm a big fan of anything craftsman (sears), they have torque wrenches on sale this weekend
"The real couple is the car and the woman" - B. Rheims
Want a 944? http://philadelphia.craigslist.org/cto/1475874116.html
Come out and play: yahoo NE 368 group http://autos.groups.yahoo.com/group/NE_coupe_group/ my track schedule http://www.MyTrackSchedule.com/ViewU...serName=mz.368
Old 02-26-2006, 05:22 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Bigger range means larger error as the error is normally a percentage of the max torque or the range.
Oil pan nut needs a low range 3/8" drive. WHeels and bushings require a higher range 1/2" drive.
Suck it up and buy two.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 02-26-2006, 06:03 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
I have a few torque wrenches, based on the vehicle I use them for; go kart needs inch-Lbs; Healey is foot-Lbs; and the ones I use for BMWs are made by Armstrong and calibrated in Nm-Meters. I don't like to do conversions, if I don't have to.
Ninety percent (90%) of what I do on BMWs is covered by the 3/8" drive 10-100 Nm-Meter version. Using my 4:1 torque multiplier, I can even do the 300 Nm-Meter axleshaft/hub nuts!
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 02-26-2006, 06:57 AM
Sands's Avatar
Sands Sands is offline
With the type of wrench that Randy showed, make sure that you return it to zero after each use. There is a spring in there that makes it 'click'. Not returning it to zero will eventually loose it's calibration. If you are worried about calibration, there are on-line shops that do it or most engine builders will have the gizmo that check torque.
yes, buy two. One in the up to 100 ft-lbs or so range for the bigger suspension and wheel bolts and nuts and one 3/8" drive in the in-lb range for the smaller nuts and bolts.
Sands (aka Ian)
2000 M Coupe
Cosmo Black and no moon roof
IE Bushings all around, IE toe and camber kit
SS clutch line
VPD cooler cap & and a real Setrab cooler
Racetech pilot seat, schroth harnesses
Obey your Noodly Master! Ramen.
Old 02-26-2006, 07:09 AM
Also, NEVER continue to pull on it after it has clicked.
Randy Forbes
Old 02-26-2006, 08:37 AM
haiku99 haiku99 is offline
Mein Auto: 1999 Z3 2.3
me too, have has a click type 1/2" for years and it works well....also FWIW the 5% accuracy claim is valid (for mine at least), I built a torque wrench tester for an engineering class project and my wrench was within specs...
Old 02-26-2006, 10:45 AM
That's what I wanted to hear.
Thanks all.
Old 02-26-2006, 04:38 PM
Pinecone's Avatar
M Mad
The Craftsman digital torque wrenchs haver settings in both foot-pounds and newton-meters. No conversions required.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 02-26-2006, 06:32 PM
DaveZ's Avatar
DaveZ DaveZ is offline
The knights who say Ni!
Mein Auto: 2006 Z4 M Roadster
So do the SK torque wrenches that I bought at Coastal Tool.
DaveZ - http://www.zeleznik-klein.com/z4
2006 MZ4 Roadster, Interlagos Blue, Light Sepang, CF Trim
CDV delete, OEM Strut Bar, Homelink, smartTop Controller
Old 02-27-2006, 07:07 AM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
Also never use your torque wrench as a breaker bar.
Old 02-27-2006, 07:59 AM
Are you saying Not even putting a pipe over it?
Old 02-27-2006, 12:20 PM
rjcoston's Avatar
///M Practical
I was mainly referring to using one to loosen tight bolts. But I would personally also not use a pipe on a torque wrench even when torquing down a bolt. If I couldn't achieve the desired torque, I'd use a multiplier like Randy's.
http://home.jtan.com/~joe/KIAT/kiat_3.htm
Old 02-27-2006, 02:09 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
I bought a Craftsman Inch/pound wrench and like it a lot. I dont have any way to judge its accuracy but it feels and looks like a quality tool.
I purchased the inch/lbs as it was most handy for bike, motorcycle and car. I just up convert for foot/lbs.
Photobucket
Old 02-27-2006, 02:10 PM
Thanks for the info.
I needed that.
Old 02-28-2006, 09:58 AM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
I have a MAC
In 1972 I bought a MAC 10-250# 1/2 drive racheting torque wrench. I used it ever since. I had it calibrated every 2 years and this cost me anywhere from $20 to $50 . Two years ago it stopped working(wouldn't click). I sent it to Mac and they replaced the head and calibrated it for $89. I lent it to someone who broke the locking collar spring and this time MAC lost it when relocating the service center. MAC acknowledged the lose and replaced it FREE OF CHARGE with a brand new 20-250# flex head racheting unit. Sometime spending the extra for a tool pays off many years later. I'm still a bit miffed at them for loosing the old wrench but they did the stand up thing 33 years later. I think that says something about a company in this day and age.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 03-01-2006, 07:17 AM
IMR IMR is offline
Mein Auto: 2005 X3
I can't recommend the Precision Instruments stuff highly enough. It feels like precision...
http://www.tirerack.com/accessories/...i_c3fr250f.jsp
MAC and Snap-on are nice, but those two have ideas about pricing I have trouble with. Armstrong is nice too, that's a brand of Danaher Corp, which also makes the Craftsman stuff for Sears. (Danaher is also an awesome stock to own, if anyone is interested.) A friend has a Facom wrench he paid a fortune for, and it seems to go out of calibration every time he looks at it cross-eyed. I picked up a bunch of Facom rachets from Griots years ago because they felt nice and seemed to work with precision (72-tooth gears), but they seem to stop working every so often, so I'd stay away from Facom anything. Funny, SK is the US arm of the same company and their stuff is very reliable. Hmmm.
Old 03-01-2006, 11:25 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
I agree with the Snap-On pricing issue, and the Precision Instruments wrenches are nice. But I do really like my Snap-On TechWrench set. 1/2" 25-250 lb-ft, 3/8" 5-100 lb-ft, 1/4" 20-240 lb-in. Tool fetish.
Daniel
2002 M roadster
Old 03-02-2006, 08:53 AM
IMR IMR is offline
Mein Auto: 2005 X3
Those are gorgeous! That's quite a fetish you've got there! I hope you've developed a very good business relationship with a Snap-on dealer.
Old 03-03-2006, 09:39 PM
viper501's Avatar
viper501 viper501 is offline
lost and confused ...
Mein Auto: 911 gone. Coming soon...
FYI, spotted this one .... http://cgi.ebay.com/ebaymotors/MAC-T...QQcmdZViewItem
Old 09-22-2009, 06:51 PM
chargedZ chargedZ is offline
Mein Auto: 2003 Z4 3.0
car torque specs
I have been searching the forum and can't seem to find anything.
Has anyone posted a bolt torque spec quide for the Z4?
Thanks...
Old 09-23-2009, 01:10 PM
jmillet's Avatar
Thumbs up Tis dvd
Thanks...
The TIS DVD contains all the torque specs you need. Get one here:
http://cgi.ebay.com/ebaymotors/BMW-Z...sQ5fLiterature
Jim Millet
Old 09-23-2009, 02:01 PM
Hey Jim, thanks for the reply...that's perfect! Doesn't seem that expensive either, so good news...
Similar Threads
lug wrench? torque wrench? swchang Tire Rack's Tires, Wheels, Brakes & Suspension 49 01-14-2008 04:58 PM
OMG, the importance of a proper torque wrench. bluskye General BMW Questions 10 09-15-2003 10:13 AM
Wheel bolts: Torque Wrench or Hand Tighten? OBS3SSION Do-It-Yourself H.Q. 21 04-29-2003 01:41 PM
Stupid Q: How to use a torque wrench? SchwartzBlack General BMW Questions 3 04-20-2002 08:06 AM
