Old 09-22-2009, 03:44 PM
S93D S93D is offline
Mein Auto: BMW
Money fell under back seat
There's a small gap between the seat and the rear seat belt receptacle. I dropped 26 cents in there. Anyway to retrieve it easily (maybe by removing the trunk floor and driving up a hill? I think it will be a gift to the 2nd owner of the car!
Old 09-22-2009, 04:57 PM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi
I noticed that gap when I cleaned the interior yesterday and removed a carseat. I'm actually kind of scared what kind of crumbs I will find down there from my daughter!!
Old 09-22-2009, 05:22 PM
minicrazy592's Avatar
minicrazy592 minicrazy592 is offline
about the mini part....
Send a message via Skype™ to minicrazy592
Mein Auto: E90 M-tech, E30 M-tech
I took mine out a few weeks ago. It isn't hard to get out, but get it back in is the challenge. Just pull up around the front side edges. There should be 4 pops I believe from those 4 clips you see near the bottom of the seat in the pic. You also may have to take out the side bolsters to get it back in, not hard either. Just start tugging around in the back and you should hear things pop. I found 16 cents, old, dried, sticky, coke, and rose petals?!
-J.T.
Will be missed: 04' E83 M54B30
Old 09-22-2009, 06:23 PM
AzNMpower32's Avatar
Tar Heel Faithful
Send a message via AIM to AzNMpower32
Mein Auto: X3
Remove the seat bottom. Yank sharply up from the front edge of the rear bench. Getting it back is more difficult and requires a bit of patience and finesse with the seatbelt buckles.
Old 09-23-2009, 11:15 AM
Mein Auto: BMW
Or wait until there's a dollar or more in coins to save effort!
Old 09-23-2009, 12:51 PM
Tar Heel Faithful
Mein Auto: X3
The X3 only accepts Euro coins. USD is not worth very much thesedays.
Old 09-24-2009, 03:18 AM
-J.T.
Old 09-24-2009, 04:18 AM
archrenov8's Avatar
archrenov8 archrenov8 is offline
archrenov8
Mein Auto: '08 X3 since April '08
No need to remove the side bolsters. When you are putting the bottom cushion back, you get the seatbelts partially inserted through the three holes, and then I found that if you attach the male end of the buckle to the female, you can then pull the strap up while pushing the cushion down. If a third hand is available, it would be helpful, but is not totally necessary. Once you have the back of the cushion secured down with the three seatbelts fully pulled through, you can push down the front edge. Then you snap the plastic pieces back into place.
I have done this several times this summer, when I wanted to load the X3 up and have almost a totally flat loading floor. Too bad they didn't make this easier.
'08 X3, MT, Titanium Silver on Tobacco/Black with Brushed Aluminum Trim, Servotronic, Htd steering, rear side air, Park dist, Xenon, Nav, Priv Glass, Premium, Cold pkge.
