E30 (1982 - 1993)
Old 09-23-2009, 11:00 PM
sde30 sde30 is offline
Top Down Squad
Mein Auto: 1987 E30 Convertable
instrument cluster lights
i tried searching but found nothing. i have a 87 325i and the cluster does not light up at night. i replaced both wedge bulbs with new ones and it still doesn't light up. everything else works on the cluster/ lights up but not the faces/needles. any suggestions?
Old 09-24-2009, 02:46 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
try rotating the knob you pull to turn on the headlights
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 09-24-2009, 07:18 AM
Top Down Squad
i tried the dimmer switch already. the climate control/dash lights work fine, but the cluster still won't light up. the 2 smaller ones for the check engine light and abs work but not the face illumination
Old 09-24-2009, 09:27 PM
bulbs must not be in properly, or if its not that then the curcuitry of the gauge cluster has corroded
E30 above Sold
Old 09-24-2009, 09:36 PM
danielw05 danielw05 is offline
Send a message via AIM to danielw05 Send a message via MSN to danielw05 Send a message via Yahoo to danielw05
Mein Auto: 1990 325i
i would suggest to try a different SI board or get a used cluster.
Old 09-25-2009, 09:45 AM
Top Down Squad
yea what i feared with buying an old car... thanks guys the hunt for a new cluster is on.
Old 09-25-2009, 01:40 PM
claver claver is offline
Mein Auto: 1997 328i
have u check the fuses??? i think 18 controls the cluster lights
Old 09-29-2009, 11:31 AM
Top Down Squad
yes i checked all the fuses. i rigged both lights to another power source and they work fine now. thanks guys.
