E30 (1982 - 1993)
Old 09-24-2009, 03:20 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
KM to Miles Conversion
Does anyone know how the counter in the cluster works? where is the convertor that decides whether to make the odo turn slower to reflect miles or faster to reflect kilometers? i want my euro MPH gauge, but would like the odometer to count in kilometers (currently counts in miles).
i guess as a starting point do the KMH and MPH clusters use different odometer gears?
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 09-24-2009, 10:15 AM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
you need one of these:
this is what I use when I fly for all sorts of different things, among them miles to kilometers conversion.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 09-24-2009, 09:24 PM
:P
was thinking about it today and i thought i might be able to swap the gauge face itself over. how do you take the needle off if possible? i dont want to brake it!
E30 above Sold
Old 09-24-2009, 09:29 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
Originally Posted by Ethrty View Post
:P
youi just pull .. but its very easy to break, some come off nice and some you'll rip the whole piece off and ruin it all
but swapping the face will mess your reading all up
trim ?
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 09-24-2009, 10:19 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
will swapping the faces really change the reading??? at first that made total sense to me but as i think about it more, it would have been really intellegent of bmw to make universal clusters and just different faces for them. and since we know how intelligent germans are couldnt you just swap the faceplates out?
unless of course our wonderful german friends OVER-engineered it... lol
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 09-24-2009, 10:32 PM
the face on the gauge will say that the odo is in miles, but i know that really it will be in kilometers and the gauge face was changed. i cannot see why that would make any difference?
E30 above Sold
Old 09-24-2009, 10:47 PM
fcsteve's Avatar
610EUROs
should be ok. i just realized i was looking at my grey market speedo and comparing it to the US speedo. should have been looking at my full euro speedo vs the US one. looking at the correct ones it should be good. too many parts here
i wish they made a km/h gauge that also read mph in the center like the US speedo has. then i coulsd run a full euro cluster and not this basterdized piece i have i thought about running the full km/h gauge but then i really have no clue how fast im going when i get pulled over
Old 09-24-2009, 10:53 PM
100 is the speed limit on the highway, 50 around town etc.. just like 100 degrees celcius is when water boils, and there are 100 centimeters in a meter. Metric is far easier to get your head around than imperial! metric ftw!
i agree on wishing there was a metric main and imperial secondary, but the other way around will do for me
Edit: are motometer and VDO fuel and temperature gauges interchangable?
E30 above Sold
Old 09-24-2009, 11:02 PM
fcsteve's Avatar
610EUROs
speed limits change on nearly ever road here so it would be hard to guess what the km/h to mph would be on each road. metric is much nicer.
Old 09-24-2009, 11:28 PM
there is no simple formula for converting it. 62 (60)=100 so 30 = 50, 40 = 65... ahhh maths! as long as the gauge is hanging off the end of the gauge you should be sweet :P
E30 above Sold
Old 09-25-2009, 12:55 AM
before and after photos. i quite like the new setup. looks the part. the counter should count in kilometers still hopefully. i used the cover off the european car (so a close eye will pick up that it says VDO instead of Motometer now). im hoping its the main board that decides to count in miles, or the counter itself, rather than the SI board, but i guess we will see. i swapped over the fuel gauge but kept the face as i prefer the gauge reading how many liters over the amount relitive to a full tank (ie 1/2 etc). also swapped the temperature gauge, im hoping this might fix my unreasonably high temperature problem.
ID:	202737   Click image for larger version
E30 above Sold
Old 09-25-2009, 12:58 AM
jleon426 jleon426 is offline
e30 project
Send a message via MSN to jleon426 Send a message via Yahoo to jleon426
Mein Auto: lokking for an e30
aaaahhhhh i tough that was my cluster?
http://i301.photobucket.com/albums/nn63/Supaflyw00t/Moonwalk.gif
Old 09-25-2009, 02:04 AM
i have a few stashed away :P
temperature gauge is sitting right in the normal place, the speedo and tacho both work so thats good! i have a full tank of gas at the moment so i will see if the swap on the fuel gauge has worked on that. it usually drops to zero when there is about a half tank left. ill swap the sender if this hasnt fixed it. i assume that the fuel level sender is the same between M20 and M40 equipped cars? i guess ill find out in due course anyways
E30 above Sold
Old 09-27-2009, 09:32 AM
ScottinSoCal ScottinSoCal is offline
Mein Auto: So. California
Yes there is. 1 KM = 5/8 of a mile.
Miles to kilometers: Divide by 5, multiply by 8.
60/5 = 12. 12*8 = 96.
60 mph = 96 kph.
Kilometers to miles: Divide by 8, multiply by 5.
96/8 = 12. 12*5 = 60
96 kph = 60 mph.
Old 09-27-2009, 09:52 AM
fcsteve's Avatar
610EUROs
60 mph = 96 kph.
96 kph = 60 mph.
try this while driving ... not simple
Old 09-27-2009, 10:31 AM
^^ thats where the whiz wheel comes in.
Old 09-27-2009, 04:06 PM
60 mph = 96 kph.
96 kph = 60 mph.
im not used to fractions. i never need them in life. if a unit gets small/accurate enough to require fractions, you drop down to the next unit. metric ftw lol.
and im crap at maths... i know my 5 times tables.. not my 8s
E30 above Sold
Old 09-28-2009, 01:00 PM
romeomike's Avatar
romeomike romeomike is offline
Running life's race...
Mein Auto: 91 318i
Time and driving conditions permitting, you could practice doing the mental math every time you see a speed limit sign. Miles to km conversion in decimal format is multiplying miles by 1.6, but here are four to memorize to start:
25 mph = 40 km/h
50 mph = 80 km/h
75 mph = 120 km/h
100 mph = 160 km/h
Adios for now,
RM
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
Old 09-28-2009, 01:04 PM
25 mph = 40 km/h
50 mph = 80 km/h
75 mph = 120 km/h
100 mph = 160 km/h
Adios for now,
RM
you have 40km/h speed limits???? damn! our lowest is 50 (except for parking lots which is 10). wish we could have 120km/h. i do that anyway but it would be nice to not have to worry
E30 above Sold
Old 09-28-2009, 04:53 PM
romeomike's Avatar
Mein Auto: 91 318i
24 km/h -- school zones (along with 40km/h)
40 km/h -- residential streets and rural communities (where giving speeding tickets seems to be the town's main source of income).
We have limits in 8km/h // 5mph increments all the way from 40 // 25 to 120 // 75. More info below
http://en.wikipedia.org/wiki/Speed_l..._United_States
Old 09-28-2009, 05:28 PM
we have 20kmh at schools, (but thats not enforced and there are no signs) and then simply 50 (residential/industrial), 80 intertown roads, and 100 (open road/motorway etc
E30 above Sold
Old 09-28-2009, 09:17 PM
Jetpilot718 Jetpilot718 is offline
Send a message via AIM to Jetpilot718
Mein Auto: E30 325ic
Holy hell, I wouldn't even remember which way to hold an E6B. Now this, this is what you need to convert well, anything!
