E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Want to see what could happen to a 21 year old shifter?
So I had problems shifting into the 3rd and the 5th gear of the E30, and I think this picture explains why.
Andy 06 M3 ZCP CB/black 6 speed 14K miles 12 CTSV Wagon Diamon black/black 6 speed 88 325is Black/Cinnamon 5 speed |
Wow, great time to get a Z3 or a Z4 shifter upgrade.
Use this place, just got mine in. http://www.trademotion.com/partlocat...72&catalogid=0 Order this stuff: 25117543193 SHIFT LEVER 1 $61.68 25111220439 SPEC. SHIM 4 $0.20 25117519669 BUSH BEARING 1 $9.54 25117571899 SECURING CLIP 2 $0.53 That is the codes on the left that you place in the part number box. They are WICKED cheap, and all OEM. |
ive had a bunch of 5 speeds and even the extremely rusted linkages were never even close to breaking. you just got a bad one.
.. talk about trying to force a shifter on someone
if you want to lead the orchestra, you must turn your back on the crowd ![]() build: http://www.bimmerfest.com/forums/sho...d.php?t=382667 |
maybe he's just super strong.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines |
I saw the title of this thread and the picture is pretty much what I envisioned.
![]() dj
'08 535i Deep Sea Blue Cream Beige Dark Poplar 6 Sp Manual Sport Premium Rear Shades BMW CCA #392316 |
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
What? if he has to replace it why not upgrade? My Dealer wanted 80 bucks for the the shift lever alone.
"Use this place" "Order this stuff:" .. sounds more like commands then advice. judging by his other posts im sure he knows what he wants in a new shifter.
Guys guys.
![]() The Z shifter sounds interesting, I will look into it. Now, hopefully this is the last piece of 21 year old thing that breaks. I think I have replaced just about everything else.
![]() ![]() ![]() ![]() this is what i thought... then i had to replace my e-brake cable, motor mounts, and rear strut mounts.... and im thinking a new icv is my next purchase
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
there is always more things that will need replacing
must be some whacked out crazy thing you stateside owners have...
i misquoted.. "shockmounts" http://cgi.ebay.com/ebaymotors/BMW-E...QQcmdZViewItem
im positive you have them on your vehicles as well the rubber bushings go bad causing the new bilstien shocks you just installed to clunk up and down.... it was a sad day
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
