Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 09-08-2003, 07:36 AM
NickD's Avatar
NickD NickD is offline
Send a message via AIM to NickD
Mein Auto: 1999 BMW 328i 5speed
Battery replacement
Hey guys. This morning I awoke to a dead battery in my car. It went without any warning. I drove ~80 miles late last night, accidently left my radar detector plugged in over night and this morning it was dead.
The strange thing was when I went to start it it clicked like a normal car with a dead battery however the xenon lights were coming on while I was cranking. I got a jump start from a neighbor, however the first time I tried to start it I got the exact same results. The xenons came on and the car made the exact same noise. Then I got out of the car, checked everything, tried one more time and started right up. I just want to make 100% certain it was indeed a dead battery.
Also, where is the best place to get a battery replacement? I heard with the aftermarket batteries you need to get the vent kit as well. Any suggestions?
Old 09-08-2003, 10:25 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Sounds more to me like you left your headlights on and that drained the battery. Otherwise why would the Xenons fire up when you crank the engine?
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 09-08-2003, 10:34 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
Auto-lights?
Often in modern cars, accessories will appear to work fine but the battery will be too low for starting the car. This happened last month to a friend of mine with a Civic.
As for venting, I don't recall ever seeing any vent plumbing in a E46, even in my wagon where the battery is in the passenger compartment. There is a slam vent right behind the battery compartment, though.
Also, I don't know if there is an aftermarket battery out yet that is an exact fit. BMW has often relied on a lip around the bottom to hold their batteries in place and that's something most aftermarket manufacturers don't bother with.
Old 09-08-2003, 10:45 AM
The HACK's Avatar
Originally Posted by Kaz
Auto-lights?
Not on a '99 328i, at least not from the factory.
Still, it takes about 2 days to drain the battery with the parking lights. The V1, if plugged into the cigarette plug, should shut off after about 45 minutes. If hardwired to accessory power, should have turned off when the key was removed.
Anyway...4-5 years seems to be the lifespan of BMW batteries unless a lot of extra tender loving care is used.
Old 09-08-2003, 10:49 AM
NickD's Avatar
My car does have the auto shutoff for the lights. The parking lights will stay on but not the main headlights. Perhaps something is getting left on but I checked everything and there seemed to be nothing left on.
Old 09-08-2003, 10:52 AM
The HACK's Avatar
ALL E46es have that feature. If you turn off the key the headlight goes out. That is not what Kaz meant by "auto-lights". '02 or later with premium package comes with automatic headlights that TURN ON in low-light situations.
If you leave your headlight SWITCH turned to the "on" position the parking lights will remain on and those will sap your battery in about 2 day's time.
Old 09-08-2003, 10:54 AM
NickD's Avatar
My parking definitely weren't on. As I remember walking around the front of the car.
I was thinking perhaps that the xenon lights powering up when I was trying to start the car was putting too much of a drain on the system and preventing the car from starting. I don't know why these would come on at all since the switch was in the off position.
Old 09-08-2003, 11:08 AM
The HACK's Avatar
Once your batteries are drained the lights won't stay on. What is WEIRD is it requires a lot more VOLTAGE to crank the Xenons than the regular lightbulbs. Eitherway, it still sounds like you're about due for a new battery anyway. I believe Interstate is the only aftermarket battery maker that makes one compatible with BMWs.
Old 09-08-2003, 11:52 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
This is incorrect. I believe the Philips LVQ212 ballast will start on as little as 9VDC. It's the ballast/igniter's job to step that up to create the brief ~20,000v ignition voltage and the 85v running voltage.
Also, I believe US OE BMW batteries are from Douglas, not Interstate.
Old 09-08-2003, 02:16 PM
NickD's Avatar
Ok, I just spent the past 3 hours locating a interstate battery, the model is MPT-91 for an E46. Got a ride there from a co-worker, came back, installed the new battery, ($3.50 for a vent kit) and it started right up, no problems. I guess the car does wierd thing when the battery gets weak (like turning on my headlights).
Thanks for all your help guys!
