Windshield washer problem - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 09-24-2009, 10:07 PM
BMWmarty BMWmarty is offline
Mein Auto: 98740iL
The windshield washers on my 740iL seem to be plugged,but I can't see where the fluid comes from or any tube that needs clearing. Can anyone help me out? Thanks
Marty
Old 10-14-2009, 06:39 PM
srein1 srein1 is offline
Mein Auto: 2000 740i orient blue
by this age in your cars life, if you have not cleaned out your washer fluid tank and associated hoses it is probably blocked there -- but it could be as simple as blocked nozzles. get a metal guitar string or similar thin wire to clean out the nozzles. if that does not work check your washer pump and tank and lines. Unfortunately, to get to your pump you have to take off the splash panel just behind your right front wheel. Its really not hard to do.
