Old 09-26-2009, 04:41 PM
Brycenarches Brycenarches is offline
Mein Auto: 2008 BMW 335xi
Noise coming from Right Front Wheel/Axle area
I have a 2008 BMW 335xi. There is a loud noise (clunk sound) that comes from the right front wheel/axle area when I first start driving. The noise doesn't happen all the time, but it especially happens when the car had been sitting around for a while or when the weather is cold. It's a loud noise and you can almost feel the clunk. And it happens when I first start driving.
Also, when I go over a speed bump, I get a noise from the same area (right front wheel/axle) although it's not as loud (more of a clicking sound instead of a clunk sound).
I can't replicate this noise at the BMW dealer because by the time I drive the car to the dealer, the car has been driven for a while and the car has warmed up.
Any ideas on what's causing the noise? What part should I have the dealer look at? Anyone else have a similar problem?
Thanks, I appreciate any suggestions.
Old 09-26-2009, 04:42 PM
hpowders hpowders is offline
Mein Auto: BMW's: E90 and F22
Welcome!
2015 Alpine White 228i Coupe ("El Chapo") with Sport Line, Premium Package, Black Dakota Leather, FineLine Stream Wood Trim, Lighting Package, Driver Assistance Package and Track Handling Package and those wonderful non-runflat Michelin Pilot Super Sport Summer Tires.
Old 09-26-2009, 04:46 PM
TofuTurkey's Avatar
TofuTurkey TofuTurkey is offline
Gooble Goobledygoook
Mein Auto: 08 335xi E92
Disclaimer: I don't really know what I'm talking about
Could it be that some moving parts seized? Did you feel some resistance before the car started moving, i.e. you have to step on the gas more and suddenly the car jerks into movement? Can't be rust, can it? Did you try leaving it at the dealership for a couple of days, then let them drive it and see if the problem still exists?
Old 09-27-2009, 09:50 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
It could be a bad bearing. Try to load the bearning when it's warm, by driving hard into a left turn and see if the noise increases in the area of the right wheel. I test drove a BMW couple of years ago and I noticed when I turned left, the car had a noticeably louder noise in the right wheel area. Even the salesman noticed it. He took into the shop and they said the bearing was worn. It doesn't happen often on modern cars, but that could be your problem.
Old 09-27-2009, 01:18 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
Does the noise happen when you apply the brakes when you first start driving? If so, you are probably hearing the pads shift in the calipers when you apply the brakes.
This could be shock absorber or strut bearing noise.
The Magic 8 Ball says a visit to the dealer is in your near future and you will have to leave the car at the dealer overnight so they can try to replicate the problem.
Old 09-30-2009, 06:22 PM
thanks
Thanks to all for replying. I am going to take my car to the BMW dealer and ask them to look at the components that you mentioned. I really appreciate you all.
