Old 09-12-2013, 08:22 AM
Hello Hello is offline
Mein Auto: 2007 525i
Cool 07 525i shifting issues from P to D
When I start drving the car from a stop position, the car takes more than usual amount of acceleration but does not move or moves slowly then jerks to shift in 2nd gear. It drives smooth after that until I stop again. Anyone having similar issues or "transmission surge SIBs" is a fix for this as well. I'd much appreciate any insight!!
Old 09-12-2013, 08:35 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Need to pull the transmission error codes to get an idea of what is going on
Old 09-12-2013, 08:46 AM
I'm not getting any messages from the car but I've an appointment at the dealership for next friday so I'll let you know what I hear back from them. Thanks for the quick response. But is this a usual problem with this model BMWs (I'm a first time new owner...)
Old 09-12-2013, 10:07 AM
DIY'er
Yeah, it probably still has some errors or information stored that they'll be able to get
I'm not sure exactly what your issue is to be honest
Old 09-12-2013, 10:32 AM
Cool Thanks! Lets see what they find...
Old 09-12-2013, 11:20 PM
Sid58 Sid58 is offline
Mein Auto: 545i
Transmission problems
My 545i did the same thing I took it to ZF transmissions in Johannesburg and they did a service exchange and now it is like new - this was a very expensive exercise but well worth the money. You will find that your solonoids are blocked and they do not sell individual solenoids so you have to replace the whole gearbox
Old 09-13-2013, 04:04 AM
DIY'er
This is absolutely incorrect. Either they didn't know what they were talking about or they were lying. I have posted not only where to get the solenoids (they ship straight from zf by the way) but also I made a video and put it on YouTube showing exactly how to change them out (from when I changed my own..)
So, your options should have been:
-Solenoid kit with all solenoids included i.e. replace all solenoids
-Individual solenoids i.e. replace the solenoid that was the issue if it was only one
-Rebuilt mechatronics unit (with presumably new solenoids) as well (even BMW offers this option, albeit their prices are quite high)
All of these options would have been much much cheaper, but at least you know you won't be having anymore problems any time soon
Old 09-13-2013, 09:38 AM
BeameD BeameD is offline
Mein Auto: 2005 545i
4f89???
Originally Posted by schpenxel View Post
Awesome! Another check in the successes column!
Screw you BMW and your lack of willingness to change what is actually wrong and taking the easy way out.
Wish I could say the same.
I ordered replacement solenoids, adapter seal, sleeve seal, and pan/filter with new fluid and new bolts. Followed all of the steps for trans fluid refill including the reset of Adaptor settings before and after via INPA. Took the car out for a drive and everything was fine. No leaks or error messages. 5 hours later after driving around, I hopped on the interstate to head home and the car jerked and then went into safe-mode. Car would not change gears. Seems like it was stuck in 3rd gear. Managed to make it home by use of side streets at 40mph.
Got home and pulled the error codes 4F85 and 4F89. So, I checked the filter for leaks and noticed fluid sweat on one of the pan/filter bolts and fluid stains underneath the undercarriage of the car that smelled like trans fluid. Warmed the car up to check the gearbox temp via INPA. When the gearbox reached 40c degrees and opened the fill plug, no trans fluid came out. I checked the sleeve seal for leaks, but found none. I drained out a little over 6liters of trans fluid and loosened the pan-filter bolts and re-torqued them. Per the re-fill instructions, I added fluid back into trans. Checked for leaks and found none. Took car for test drive and as soon as I got it up to 40mph, Transmission Malfunction safe-mode. Pulled the codes and this time only the error code 4F89 remained.
Thinking that maybe it was the new solenoids, I drained the trans fluid and removed the mechatronic and sleeve seal and put the old solenoids back in. Reset trans adaptor settings before/after and completed refill instructions. Took the car out for a drive and the damned thing went into safe-mode AGAIN! Same code pulled. Here are the Error messages below pulled from INPA.
Error Memory:
4F89 Ratio control 3-4
P17E8 Ratio monitoring Shift 3-4
2 Error codes in Info Memory:
4F86 Ratio-monitoring Symptom Circuit-monitoring
Torque converter clutch open (Type of shift 2 after 1, shift 1 after 1,4F shift 3 after 4)
4F80 Ratio-monitoring Symptom gear-monitoring
Torque converter clutch open (Type of shift 2 after 2, shift 1 after 1, shift of R to R)
I am at a stand-still and ready to get a rebuilt tranny at this point.
Any idea what the problem might be?
Old 09-13-2013, 10:05 AM
DIY'er
Really hate to hear that outcome. Sounds like something slipping to me but I'm not sure what else to do. 3 to 4 was where mine had trouble prior to the new solenoids, but it has been fine ever since. I wonder if the clutch pack(s) or band(s) involved in that shift are just plain worn out?
edit: the codes in memory sound more like an issue with the torque converter than the transmission though
edit2: Everything I can find on the ratio monitoring code still says it's valve body / mechatronics related
Old 09-13-2013, 03:00 PM
spitfire23 spitfire23 is offline
Mein Auto: 02 530i, 07 530xi
Re: 05 545i Transmission Surging Issues help!
Quick questions...do I need to reset the adaptations after changing fluids?
I ordered the INPA cable almost 2 weeks ago from One Stop. Does this seem excessive? Tracking says still in Hong Kong.
Sent from my SAMSUNG-SGH-I747 using BimmerApp mobile app
Old 09-13-2013, 03:16 PM
DIY'er
Yes you need to
Old 09-13-2013, 03:34 PM
Damn.. ok. Can't do anything until the cable shows up.
Old 09-13-2013, 05:48 PM
DIY'er
Mine took right at two weeks--it'll go fast once it hits the US
Old 09-18-2013, 07:20 PM
Still waiting... got fluid and pam but still dead in water til cable shows up
Old 09-20-2013, 12:05 PM
bugsd bugsd is offline
Mein Auto: '13 335i
surging at 35-40
Have a shop clear your transmission adaptation and reset teach in. See if this clears the surging. If it doesn't, more than likely you have a mechatronic problem or a torque converter clutch failing.
Old 10-11-2013, 11:01 AM
cory720204 cory720204 is offline
Mein Auto: 525i
To reset the adaptations can I just do the turn key to 2 position and hold gas pedal or will that not work for this?
Old 10-11-2013, 11:14 AM
kiwi_chris kiwi_chris is offline
Mein Auto: 2004 BMW 535D
No you have to reset adaptations via INPA or some other ODB diagnostic tool.
Old 10-11-2013, 11:22 AM
DIY'er
Personally I think the "pedal on the floor for 30 seconds" thing is complete BS.. I've seen people say it does everything from reset the throttle adaptations, valvetronics calibration, transmission adaptations.. and probably a few others.
I can only say that it absolutely did not work for me. I had a violent jerk in 5th gear after the first time I changed my fluid (original fluid at 180K miles..). I tried the 30 second thing and no change. A few weeks later got my INPA cable, reset adaptations, and instantly the jerk was gone (I started getting some other errors, but that's besides the point)
Old 10-11-2013, 12:41 PM
Mein Auto: '13 335i
No you will need to use a tool that uses factory level (Autologic or ISIS) software. Along with clearing adaptation your technician will need to perform a fresh TEACH-IN also.
Old 10-11-2013, 12:43 PM
DIY'er
You don't need Autologic and you don't need ISIS. INPA does it just fine.
Old 10-11-2013, 12:58 PM
Mein Auto: '13 335i
Well hey! sounds like SCHPENXEL has a solution with a cheap tool for you.
Old 10-11-2013, 01:01 PM
DIY'er
He has one that works if that's what you mean
Old 10-17-2013, 06:35 PM
Mein Auto: 525i
Can I drive my car down to the dealership to have the tranny adaptations reset after I do the solenoid change or will that effect the repair. Do i have to reset right afterwards?
Old 10-17-2013, 06:38 PM
Mein Auto: 525i
Also I have a 525i 2004 do u know if the solenoid swap is similar to your 545
Old 10-17-2013, 08:11 PM
DIY'er
should be fine
advice, bmw 5 series, issues, tranny problems
