E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
#176
Split I am in the sames position as you, only the 2-1 downshift as I am stopping gives me problems. I have an appointment this Friday. I want a new mechatronics. Anything less than that is bull$hit, and I will raise hell.
I will update next week.
#177
So just got the car back from the dealership. $140 to reprogram.
So far so good. Not going to try and see if the shifting is happening. Going to drive normal and notice if and when it does happen again. |
#178
Update -
Took the car back to the dealer this morning, went for a ride with a tech and demonstrated the issue. They just called me back and stated that they sent up the service codes for which there were no errors in to BMW and told them what was happening. They responded back later in the afternoon and told the dealer to replace the mechatronics. They have it in stock and are installing it. I should be able to pick it up tomorrow. |
#179
Update: After a few software 'tweaks', BMW authorized a transmission replacement under my CPO warranty. I should have it back sometime Friday.
Kudos to the dealer and BMW for stepping up and taking care of the customer (hopefully). |
#180
I wonder why some of us are getting our mechatronics units switched out while others are getting new transmissions? I'm not too gear savvy but I don't think they are one in the same? What are the chances that the actual gears fail this early?
#181
^^ Sir I wonder the same thing. With 39,000 miles on my 05. I wonder if I am only experiencing minor tranny issues that will manifest into bigger ones once the CPO warranty is up in 14 months.
#182
If you have any issues, I would take it in as their are TSB from BMW on this and numerous goodwill repairs being offered. Like you I am under CPO so I only paid the $50 deductible. |
#183
^^ my appointment is this Friday.
#184
I wonder if some people are saying tranny in general terms but the dealer actually only did a mechatronics swap? Maybe they are getting whole rebuilt units because the dealer doesn't want to deal with the hassle of tearing into the tranny case and instead just drop it and put whole rebuild in?
My tech told me that having an actually gear issue is an extreme rarity. The mech unit does most of the work changing the gears. There's a bunch of valves and a whole lot of electronics that are always working. They usually don't do anything to the gears on rebuilds anyway. They usually rebuild the valve bodies and seals and that's what the mechatronics is. I'm glad more and more people are getting good results with complaining about this and getting the right fix. I hope they are all logged in and BMW starts to take notice of the problem. It's got to be something with this ZF tranny because a number of us all have the same issue. |
#185
I know SirLoins posted his dealer info, would everyone else that has gotten their mechatronics or tranny replaced be willing to post their dealer and SA info? That might be helpful for those of us that haven't gotten resolution yet.
Ex-2005 545i - Orient Blue/Auburn Dakota/Anthracite Bamboo Trim Last edited by mikewils; 06-30-2010 at 05:12 PM. |
#186
Well, Day 3 after Re-Program of the Transmission and it happened. The hiccups from 35-40.
![]() Next is the Transmission Fluid. Here is a question for everyone, I have already done my 100,000 mile service (currently 132K) and no where in the 100,000 mile service was the transmission fluid replaced. I have found through the Service & Warranty manual on the '04 E60 that the ATF (Automatic Transmission Fluid) is to be replaced every 100,000 miles. So there is no question that I will get the transmission fluid replaced for free or for the $50 for the Ext. Main. of the CPO, but the real question is do you think I can say that becuase they did not replace the transmission fluid @ 100,000 miles that the mechatronics has failed and have them eat the cost or most of it on replacing the mechatronics? Does that seem like a reasonable argument? Also, should I deal with the Dealership at that point or should I escalate to regional people? |
#187
@GPFboysJR
I wouldn't pay for the transmission fluid flush, or even have the dealership do it. Start your argument with the proper TSB's and other examples of PUMA cases on this thread that have had the mechatronics units switched out. I was under CPO and a PUMA case was opened on the matter for me. I know others out of warranty who have had goodwill repairs, only having to pay for the labor for the repair. The fact is that BMW is aware of this issue, so you'll just need to get the dealership on board with opening a PUMA case in your honor. I see your also from Atlanta. Where are you getting serviced at? Mine was done at United BMW in Roswell. |
#188
The problem was repeatable every time you came to a stop. Even after programming changes, the problem was repeatable. Fortunately, this makes it easier for the dealer to resolve... Most automakers are replacing transmissions instead of risking repairs that might not fix the problem due to bad diagnosis, IMO. I guess getting a list together with the specific issue and resulting repairs from board members might shed some light on what's really happening. ![]() I'll post the details after I pick-up the car either later today or Friday. |
#189
I have been using Global Imports here in Atlanta, but I am not opposed to going to United or BMW of South Atlanta. Not sure I care who fixes the car, I would just like it fixed.
#190
OK so on the way out of town, the car hid a minor snag. Driving down I-85 S and all of a sudden Dynamic Drive malfunction, mind you I am doing 70+MPH. Then no more than 1 second later Active Steering Failure, ABS Failure, CBC Failure (Sealt Belt System), Electrical Malfunction. Still shocked by what is being displayed, nothing says stop driving or pull over. Then I look back at the instrument cluster and the tachometer is showing RPM's but the speedometer shows nothing. 0 MPH yet still doing I would guess 70 MPH or so, could not tell since there was no speed.
Then another 30 seconds passed and everything electrical stops working and the car starts loosing power, iDrive is blank, instrument cluster is all off. Nothing!!! Then out of nowhere power is restored all systems back up still with all the same errors except I had a new one now, "Transmission Failure" Woohooo!!! Not what I needed to say while heading out on a long vacation.So I managed to pull over and turn the car off to see if a system reboot will help. It kind of did. Only half the errors were gone, but Dynamic Drive, Steering, and ABS were all still there and maybe some others but did not pay attention. We looked up in the BMW book for the closest dealership and fond one in Columbus GA only 30 miles. We made it there and had to have them give us a loaner while and leave the problem child with them. I will say that when we stopped and went inside the key reader did say that there was a Dynamic Drive malfunction but nothing else, and when the SA went outside to start the car up there were no faults showing. Go figure! At this point if they cannot find anything with the car thenit is out of here. This is finally the last straw.
#191
Anyways, the car did not seem to have the issue, of course, because of the adaptive values being reset. About a couple of weeks later here, the issues have returned. So, I called my SA and setup a new appointment. He said that they will have me go for a test drive with the shop foreman. Why can't the dealerships just contact whoever at BMWNA or whereever and research the issue, and find that the issue is occurring to multiple vehicles, and the solution is to replace the Mechatronics unit. It's at least a bit irritating to the customer to have to take the vehicle back in for service, for the same issue. |
#192
Talked to BMWNA again today, and still unwilling to help out until there are fault codes, why cant they just accept that, there are issues with their product and just fix it!
2006 750i Black Sapphire, Sport Package, PDC, Navigation, Active Steering, Cold Weather Package, Premium Package, Comfort Access, Comfort Seating, Cooled seats, Heated Rear Seats, MTEC Angel Eyes. 2005 545i Titanium Grey, Sport Package, PDC, Navigation, Active Steering, Cold Weather Package, Premium Package, K40 Caliber Built in Radar System |
#193
Update - it took a week after getting the car back from the dealer putting a bottle of fuel injector cleaner in, but the hiccups returned. Usually mild, but today at one point they were more violent. And two days ago I had two violent downshifts at separate times in the 30-35 mph range. Not as bad as before I had the sleeve replaced, but haven't had anything like that lately. Calling the dealer again tomorrow.
Ex-2005 545i - Orient Blue/Auburn Dakota/Anthracite Bamboo Trim |
#194
Took my car to put some new tires on yesterday. When it was on the lift I thought I would walk over and have a look. To my surprise, the skid plate was barely hanging on. Seems UNITED BMW IN ROSWELL GEORGIA doesn't have competent technicians capable of finishing a job properly.
I'm starting to wonder what else cut corners on during my mechatronics install? |
#195
At first the SA tried to tell me the whole no fault codes thing. He knew I wasn't having it.
They ended up doing the 2-1 tip procedure and the new software. It is shifting great. My concern is how long will this last and is there already damage to my mechatronics? Any more issues and I am going to demand a new tranny. Last edited by Bad Debt; 07-08-2010 at 07:17 AM. |
#196
Update: Tranny replaced and while it's 95% improved, it still does the same thing to a much lesser degree. Something I can live with...
Now I get a "double bump" when it shifts into third gear.
#197
Update -
Had the car back for a couple weeks now. Issue resolved with the mechatronics replacement. Also, I used to have to wait several seconds for reverse to engage. The mechatronics fixed that as well. Reverse engages as you would expect. $50 deductable. Quote:
#198
My car was doing that as well jerking in 2nd, 3rd, and 4th gear shifts around 30-50 mph. However, my car was also overheating and they found that it was the fan that would stop working of and on again. They replaced the the fan and fan housing as well as coolant expansion tank because it had also busted due to over heating. So since then the car has been not jerking I wonder if the fan was shutting off and that was the cause of the jerking.
My Rides Nick Named: 1 BAD 5 & BAD 3 When in doubt flat out. ![]() Cobb Tune, Rennart Catback non-resonated exhaust |
#199
I purchased a CPO 545i last week. I am also having surging at 35-40mph. I have the previous owners service records and he reported the same issue. All they did for him was a software upgrade and told him it was geared that way and all 545i's do it. I called my SA and he said if there is no code they won't do anything. They also said if the tech test drove it and felt the surge they would submit the issue to BMW, but they probably won't do anything since there is no code showing. So basically I would be out the $95 diagnostic fee for nothing. WTF???
#200
| Bookmarks |
| Tags |
| advice, bmw 5 series, issues, tranny problems |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
