How do I open my trunk? No power.
124K views 90 replies 37 participants last post by  QSilver7
#1 ·
So I took out my DME to send out to powerchip and locked the trunk with the negative cable unplugged, now I can't open it to connect the cable, the DME is not back yet but I don't think it will open even if it's connected... So, how do I open it? Key doesn't open it either... :dunno:
#2 ·
Put the key in, turn it until it stops, and then continue to turn about 1/5 of a turn. It has some resistance, so you think you can't.
The key will be parallel to the ground, just like when you lock the trunk, but to the other side.
mw
#7 ·
Exactly. Turning the key 45° will activate the electrical unlocking, fully 90° will unlock it. If it doesn't work one way, try the other way. You'll need a real key, not a valet key. Again, the owner's manual will be able to tell you which key you have.
here is what i did ;)
i disconnected the battery as i was working on the car doors (which has airbags)
i then by accident closed the boot and for some reason i coudlnt open it with the key.
what i did was
1) took back seat out (yes the other doors were open)
2) made small slit with utility knife in fat red power cable...
2) connected this to another car battery,
3) used door catch as ground...
4) pressed remote to open boot.
problem solved
You can not be serious.:eek:uch:
#6 ·
heres wot i did
what i did was
problem solved
#8 ·
what i did was
problem solved
There is a jump point under the hood, you could connect a quick jumper to which will give you power to the car. locks and remote will work.
#9 ·
Just stick the key in the keyhole in the trunk and turn... Anton, you gotta be kidding!
#88 ·
Actually my 2000 BMW 528I have no KEY hole to unlock so one must hire a mechanic to get in through the backseat which I found the middle part which has a hole but not being a mechanic I'm don't know how to open it. NOT all BMW's especially the older ones have a key hole one flaw you apparently didn't know 'bout so everything in the truck including my mailbox keys are locked away taking seven months to get new keys from USPS from Honolulu made. Alo Ha
#11 · (Edited)
Instructions from the owners manual that's been posted many times on how to unlock the car when there's an electrical failure:
1. As others have previously mentioned...the door & trunk lock cylinders were designed to be opened manually by inserting the key and turning it COUNTER CLOCKWISE (to the left)...PAST the normal position that electrically unlocks the door or trunk.
2. You can use the jump start locations under the hood (if the doors aren't locked) to open the trunk...ONLY...if you have the trunk lock in the unsecured vertical position ( | )....if the trunk lock is turned to the SECURED horizontal ( -- )...then you're stuck because only another MASTER key will be able to unlock the trunk (that's any of the keys you have that don't have the GRAY head...that's the valet/service key which doesn't unlock the trunk or glovebox). The trunk release button and the central lock/unlock button will not open the trunk if it is in the secured position.
#18 ·
...just put the key in the lock of the trunk and turn it to the left, it opens. . .
{Don't think of this reply as picking on you...it definitely is not...but I find it a good example to bring up a point.}
I think many people really do try to turn the key to what they "think" is the left...and fail so they give up.
The problem is...their perspective of the LEFT may be the cause of the failure. Without any context and a different perspective...they may have a point of reference that the 6:eek:o position is the starting point...so if they turn the key to the left...they are actually turning the lock cylinder CLOCKWISE (which is in the wrong direction).
That's why I try to insert that the lock cylinder should be turned COUNTER CLOCKWISE...which means that the point of view is turning the key left from the 12:eek:o position. :D
#17 · (Edited)
Easy:
1) Smash small rear triangle window on passenger side
2)Realize that you are too big to fit
3)Smash regular rear side window on passenger side
4)Realize that though you can fit now, the trunk release button is on driver side
5)Smash driver side rear window
6)Realize you cannot reach the front seat from the back seat
7)Smash driver side window
8)Reach down and press release button
9)Realize button is electrical and does not work
10) Smash passenger side window
11)Crawl through and open glove box
12) RTFM;)
#36 ·
Hi All,
Im new here .. and i've seen your thread which once happened to me.
But the thing is My car is 525i and when it happened to me i simply connected a battery to the Jump Start bolt that is in the engine..This One:
and by doing so .. the car electricity was back, and i simply opened the trunk :D
i tried to search the google for the 540 jump start point in the engine but i couldnt find it :dunno:
if you know where it is, just connect the positive side to the bolt and the negative to any place at the body that is connected to the chasis and i guess you'll have electricity back in the car..
by doing that you can simply open your trunk!
#38 ·
Hi All. Im new here ... i tried to search the google for the 540 jump start point in the engine but i couldnt find it :dunno:
The jump start location for the I6 & V8 are in the owners manual:
I6
V8
#40 ·
FYI..did you know that if you lock the trunk manually you cant use the key remote nor the button inside the car to open the boot..its for time like valet parking so they cant steal your stuff.. (similar to the glove box) for when you give them the valet key.. I found out when I thought my boot latch was broken when infact my dad randomly recided to lock my boot with the key.. just a little something people might not have realised :)
#44 ·
You're 90% correct. If you have the master remote key...the trunk release button (ON the key) will open the trunk EVEN when the trunk lock cylinder is in the secured position.
When the trunk lock cylinder is turned & left in the horizontal (secured) position ( -- ) the trunk is removed from the central locking system...so the interior trunk release button, the center console button, the driver's door lock cylinder, and the UNLOCK button on the key...will NOT unlock the trunk.
BUT...if you press the TRUNK release button on the key, or stick the key manually into the trunk lock cylinder and turn it COUNTER CLOCKWISE...the trunk will open. That's why you have to use the valet key when using valet parking and you have stuff in your trunk that you want to secure. If they had the MASTER key, they could use the trunk release button or stick the key manually into the trunk lock cylinder and access the stuff in your trunk. :)
