Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 09-29-2009, 06:43 PM
mahay mahay is offline
the new guy
Mein Auto: 1988 528e
Arrow changing speakers in e28
so guys, I'm planning on changing the speakers in the back of my 528e, how do you suggest I get to the speakers?
I've looked at the trunk, which wasn't much help. Should I take out the seat backs for the back seats? I'm totally unsure.
Would you think that I could still use the original amp with newer speakers or would I need to get a new amp as well?
The speakers I have to replace the old ones are 140 watts, but I don't know much about audio systems.
Thanks for your help.
Old 09-30-2009, 08:56 AM
6 Brit 6 Brit is offline
Mein Auto: **** you
i would def. consider a more powerful amp or your speakers will not get enough power and sound like ass
i have never done a speaker job in one of these tho so I have no recommendations as for the actual instal
I would also upgrade the speaker wires
Old 10-09-2009, 12:16 PM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
If you are planning on changing the factory radio then forget the stock amp (it only produces like 14 watts @10% distortion!) and stock wiring system with the exception of the door tweeter wires. You can get component speakers that fit in the premium speaker housings (I have 5-1/4" Infinity in mines), rewire from the head unit and add a subwoofer. I have a Blaupunkt unit that matches the BMW orange dash lights, an 8" Pioneer shallow mount subwoofer with a Blaupunkt 300 watt amp under the rear seat, stock front speakers and the Infinity's in the rear with their crossovers under ther rear seat and I could be happier. They won't hear you coming from a block away but it is definitely a great improvement from the stock system. Here are a couple of pics:
By the way, my sons ride on the back with no issues at all so it doesn't affect the seat use.
Jimmy Moreno
1995 530i
1986 535i
Old 11-02-2009, 10:16 PM
the new guy
thanks man!
Oh, do I just pull out the bottom part of the seats?
Old 11-03-2009, 10:38 AM
Mein Auto: 2006 X3
To reach the back speakers you do that from the top. Just put a hook on the grill and pull on them, you will see the screws that hold them down. Keep in mind that the speakers are 5-1/4" in the back and 4" in the front along with tweeters so they DON'T put out any bass. That's the whole reason for the subwoofer. If you are re-wiring all the speakers you will need to remove the back seats and the door sills in order to run the speaker wires along the right side and power on the left. Just leave the factory wiring from the kick panel speakers to the door tweeters as these are a nightmare to change properly.
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
diy, replace, speakers
HTML code is Off
