Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 09-30-2009, 12:38 PM
FWD2003 FWD2003 is offline
Mein Auto: '02 745i
Thumbs up DIY Engine Failure / Reduced Engine Power Reset
Hi everyone, I'm posting this so no one will have to go through the hassle of taking their 7 to BMW to be raped of their prices for the same problem I recently had. The other day, my 02 745i with 110k miles was sitting for about 24 hours and when i went to start it, it was just about DEAD. couldn't get it to turn over, just clicking. Needless to say, I have a battery issue that has been taken care of since. Anyhow, once I jumped the car & had it turn over, a message "Engine Failure / Reduced Engine Power" came up on the Idrive & Cluster screens and the car wouldn't allow me to accelerate. It would rev High to Low, over and over. Eventually, the car stalled. So I waited, started it again and NO changes. Still having the problem. I tried to drive the car out of my driveway to the gas station up the street, being that i was almost empty, and figured i'd put some fresh gas in with a fuel injector cleaning. I pulled out of the driveway, and I was jerked back and forth from the High/Low rev. I pulled back into the driveway, let the car sit for about a day, started her up and still had the same problem. I read up on some similar model recalls causing that message, and spoke to some BMW reps & they insisted on me towing the vehicle in for a very expensive, out of warranty service. Every rep said this was an unsafe issue, and couldn't be fixed unless they reset the computer, changed the fuel pump, etc etc etc.... So, my FIX included, completely disconnecting the battery for about 20 minutes, then re-securing the terminals. I pushed the Start button, and the car started up with no problems or messages. This may seem simple to most, but when your 7 is acting like this, and you know it's going to be expensive, you try to find the quick DIY fix. (because these reps will talk you into believing a lot) just take the basic troubleshooting steps first. Even if this problem applies to only 1 person, I hope this will help.
Old 10-01-2009, 12:17 AM
UltZeven UltZeven is offline
Mein Auto: 2002 745LI
Thanks bro. I also have a 02 745LI and I have 101,000 on it. Glad to see people take their time and post DIY's.
Old 10-07-2009, 12:45 AM
theoutlander theoutlander is offline
The Outlander
Send a message via MSN to theoutlander
Mein Auto: 2003 BMW 745 LI
I heard that the car is designed to operate in reduced power mode when the battery is low or connectors are bad. Also, the car will automatically shut itself off if the battery is low in order to conserve just about enough power to start it back up!
Closed Thread
engine failure, reduces engine power, rev
HTML code is Off
