Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 10-01-2009, 06:13 PM
legionnaire1857 legionnaire1857 is offline
Mein Auto: 2000 540i sport
I think I broke my timing belt
I was at a stoplight and the beast just stopped idling. Doesn't crank. I can hear something spinning under the hood, but the engine isn't actually turning. Does anyone have any experience with this? Of course, this had to happen like 25 miles from where I live, it's sitting in a Rite Aid parking lot right now just waiting to get towed. I'm in the Navy and I live on base, so I can't get it towed back to my place...they won't let a vehicle on base that doesn't run. I am just about sh*t out of luck. I have nowhere to work on it except the parking lot that it's in, and I don't think I can pull off a job as big as a timing belt replacement there, not to mention the bent valves and all that noise. I might get $200 for her as she sits
Old 10-01-2009, 06:25 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
is this an E30 or the car you mentioned in your alias thing next to mien auto? t/belt can be done in 4 hours if they will let you do it.
Old 10-01-2009, 06:30 PM
It's my 1988 325is. I also have a 1987 535is (no brakes!)
Old 10-01-2009, 06:33 PM
judging by your post count i thought it probably was. t/belt is pretty easy to do. there is a good write up here:
http://www.pelicanparts.com/ bmw/techarticles/101-Projects-20-E30-Timing-Belt/101-Projects-20-E30-Timing-Belt.htm
you could do that in about 4 hours if you put your mind to it. that article doesnt mention it but take the bonnet off the car. is a 5 minute job to take it off and put it back on and makes in 10 time easier
Old 10-01-2009, 06:37 PM
Do you think that's what it is?
Old 10-01-2009, 08:33 PM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
i broke a timing belt at a stop and the symptoms were exactly as you described. I had damage to the valves, and if you have the same just changing the belt will not fix it. Do they not have auto hobby shops in the navy? If you do you should be able to keep it there while you fix it.
If not, maybe you can keep it at a friend who lives off base. Sucks dude I hope you can work something out.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 10-02-2009, 02:49 PM
Yeah, they have an auto hobby shop on base. I probably should just take it there, that's the only way they would let me tow it on base. I'm sure I can fix it by myself, there's nothing that I've tried to do to a car that I haven't gotten done. Did you have to get a new head for the motor, or did you just buy replacement valves?
Old 10-02-2009, 06:30 PM
downhiller's Avatar
livin large
just valves. but for the same price, you can probably get a head from a junkyard. but either way, get the head resurfaced, checked for cracked, and reseat the valves. of course doing all this, buying a head gasket kit is in dyer need
