E30 (1982 - 1993)
Old 10-02-2009, 01:43 PM
UNCFan UNCFan is offline
Mein Auto: 89 325i
Rubbing Issues
Mounted the Sport Max 002's on 205/50/16 and I had the rear fenders rolled, however I am still having rubbing issues. No idea what to do, maybe put stiffer shocks on the rear? Any other ideas?
Old 10-02-2009, 07:27 PM
downhiller's Avatar
livin large
roll the fenders alittle more, get a different offset rim
Old 10-02-2009, 10:29 PM
Hairy325is's Avatar
Hairy325is Hairy325is is offline
Send a message via AIM to Hairy325is Send a message via Yahoo to Hairy325is
Mein Auto: 89 325is
i am running the same size tire and its all about the offset of the rim, where is it rubbing the shock or the fender?
Live life to the fullest, See the world
Old 10-03-2009, 12:56 AM
Mein Auto: 89 325i
Fender, and yea my offset is 0. If I had an offset it would be fine, I believe. Downhiller, I was trying to avoid the whole rim swap =D.
Old 10-03-2009, 02:39 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
nice one! 0 offset ftw! only way to fix that is to roll/pull the gaurds some more. pics naow! are they dished or what? (sorry if you have already said.. didnt read the top of this thread)
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-03-2009, 07:03 PM
downhiller's Avatar
livin large
just go ahead and get some new ones, and ill get rid of the old ones. free of charge
Old 10-04-2009, 12:46 AM
useless to you.. ill take them :P
E30 above Sold
Old 10-04-2009, 01:42 AM
Mein Auto: 89 325i
There set it as my sig. Yea 3" lip on those wheels.
Old 10-04-2009, 01:46 AM
ask/pm fcsteve. thats what he had on his old car
E30 above Sold
Old 10-04-2009, 08:40 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
its just poor suspension. your suspension allows far too much travel for how close to the wheels your fenders are.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 10-04-2009, 03:53 PM
Mein Auto: 89 325i
Yep. The front suspension allows no give. The back bounces around like a seesaw. Any suggestions on what type of rear suspension I should get? Trying to keep the price rather low, however I know it is costly to work on BMW's. Someone else put the current suspension on my car before I owned it. So is there a good and accurate way to check how much the car was dropped to make sure I get the same on the new shocks?
Old 10-05-2009, 01:31 AM
post closeup pictures parallel to the road and we will be able to give you and idea. whoever said it was costly to work on BMWs has never got thier hands dirty
E30 above Sold
Old 10-05-2009, 05:26 PM
Mein Auto: 89 325i
Ok I will try to get the pictures up tomorrow.
Old 10-06-2009, 10:46 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
rear shock are easy as cake to replace, honeslty it took me 10 minutes, most of that was getting it on my dads lift, which is a pain with my car
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 10-06-2009, 11:58 AM
Mein Auto: 89 325i
See there is room there, I just need a stiffer rear suspension. Any suggestions?
Old 10-06-2009, 02:56 PM
thats the same height as my car so thats a 40mm drop. i used to be much lower more like 60-70mm but it was just too impractical
E30 above Sold
Old 10-06-2009, 07:20 PM
downhiller's Avatar
livin large
coil overs
Old 10-06-2009, 11:56 PM
Mein Auto: 89 325i
Any specific coil overs?
Old 10-06-2009, 11:58 PM
fcsteve's Avatar
610EUROs
Ground Control sells a conversion kit for $400
Old 10-07-2009, 07:04 PM
Mein Auto: 89 325i
What if I just wanted to get a stiffer set of shocks? Could I make that work?
Old 10-07-2009, 08:35 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
doesn't really work that way, get a spring with a stiffer spring rate, you'll be happy.
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 10-07-2009, 09:03 PM
downhiller's Avatar
livin large
shocks really dont have a specific stiffnes, but they do have rebound control.
Old 10-07-2009, 09:06 PM
fcsteve's Avatar
610EUROs
but poorly chosen spring rates in combination with harder shocks will blow them quickly.
Old 10-07-2009, 09:17 PM
Mein Auto: 89 325i
So what do you suggest Steve? And I know it's a little late, I was reading your bronzit thread, I hope you are doing better^^.
Old 10-07-2009, 09:23 PM
fcsteve's Avatar
610EUROs
id suggest looking for a set of rear coilover springs with adjusters. they go for sale every now and then on the forums.
a conversion kit will give you the best result and stop your issues for sure. but it would cost you $400. and you would pretty much be buying new suspension.
im sure you have told me but what is your current spring setup ?
