E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
I just brought a 1990 e30 with 162k miles for 1,600. The guy wanted 2,300 but he went down to 1,600 because there was a power steering leak. When I got home I jack up and notice the boot on the steering rack is leaking power steering fluid bad.
I squeeze the boot and there seem to be a cut on the boot. My question is can I replace just the boot which i see on ebay for 3.00 or do I have to replace the whole steering rack which cost 300.00 and 300.00 for labor.. so guys you think i got a good for the price i paid? considering that he got all the paper work and the car seem to be well maintain beside that leak..
So do I have to replace the whole rack or just the boot. How hard it is to replace the boot and is it better to replace the whole rack? also do i have to do the alignment afterward? Can someone help with these question please? Also I would work on this car but I don't have tools or a place to work on it...
![]() also did i get a good price on the car? |
you should get an alignment afterwards, or you can do a broomstick alignment, which is just measuring the distance from wheel to wheel front and back to adjust the toe.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
+1 on the broomstick alignment, i havent taken a car to the shop for that in probably 5 years
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
man... that sucks i thought i would only need to change the boot, anyone know a place to get a "NICE RACK" for a decent price... and anyone who can install it for a good price too... and is there a write up on how a broom stick alignment works...
and you broomstick alignment http://www.allpar.com/fix/alignment.html i dont use pins, i just mark the tire with a paint pin
Is there anything else I got to replace beside the rack. Meaning when I order the rack is there any other parts that I need to charge.. I might try to work on this myself when i find the time...
You should probably replace the power steering hoses, the rebuilt rack should come with the tie rods (if not get those).
i would check the sway bar links and the control arm bushings...both are pretty cheap and easy to replace
Your talking about the the inner tie rods right? The bushing need to be replace one of them look pretty bad, should I just replace the control arms or can I just replace the bushing. How can you tell if the control arm needs to be replace...
Bav. Auto has the tie rods as a unit for $44.95, of course you would need two. Some places may have the inner and outer separate, so keep that in mind. As far as the bushing goes, if it's the one I believe you're talking about that is available separately. To determine if the control arm needs replaced (the bearing actually unless the control arm is bent), you check for play or looseness. If the "boot" is tore at the bearings you probably should replace the arm (dirt, grime, etc. will cause the bearing to wear quickly). New control arms are about $80 (the bearings are installed). If the control arm has never been replaced it is likely wore. If these parts are wore you can't get a good alignment, and of course your tires will wear irregularly and/or quickly.
| Bookmarks |
| Tags |
| steering rack power fluid |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
