E30 (1982 - 1993)
Old 10-04-2009, 05:19 AM
lucyred62 lucyred62 is offline
Mein Auto: 2007 328XI Wagon
Got My new Vert-Need help
Hi all,
This site has been wonderful. I just picked up my new(old)vert yesterday. Drove it home from LI, to westchester county ny yesterday in the pouring rain! No leaking in the vert top thank god. I noticed a problem, and was wondering if someone could point me in the right direction. When I am driving at a good speed like 60-68, the car handles fine, but if I hit the brakes( for example going fast, and then getting off an exit), the car vibrates something awful. It sounds like a machine gun, and the steering wheel vibrates terrible. Is it a wheel alignment problem, or tire problem etc, or something worse. Anyone have any idea? thanks
Old 10-04-2009, 07:20 AM
E30-325's Avatar
E30-325 E30-325 is offline
Mein Auto: BMW 325is
you probably have some warped rotors on your hands
Old 10-04-2009, 10:08 AM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
+1 take off your front wheels and see if the rotors are grooved and worn. New rotors + pads can be had a NAPA for relatively cheap.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 10-04-2009, 10:12 AM
downhiller's Avatar
livin large
+ another 1 on rotors. if you go with aftermarket pads, you haved to get aftermaket rotors, or else there is a major wear issue.
Old 10-04-2009, 10:54 AM
so do you think I should get oem parts, or will aftermarket parts be o.k.? I know you said that if I go with aftermarket to get the pads and rotors at the same place, but would oem be the best? If so, where can I get them, and are they significantly more expensive? thanks
Old 10-04-2009, 03:12 PM
just go aftermarket. I got mine form NAPA they have held up nice.
Old 10-04-2009, 03:22 PM
thanks- I would get the front rotors and pads right? The back breaks wouldn't need to be redone unless they are worn right? thanks
Old 10-04-2009, 03:53 PM
sde30 sde30 is offline
Top Down Squad
Mein Auto: 1987 E30 Convertable
inspect your rears also. if it's close might as well do then all at one time to have peace of mind.
Old 10-05-2009, 12:28 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
^^^ this
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
