E30 (1982 - 1993)
Old 10-08-2009, 04:15 PM
k3marissa k3marissa is offline
Mein Auto: 1986 325 ES
Question Rear lights?
How do i replace ONE rear light, all the other lights in the back are fine except the one on the left. Not sure what to do? My dad's been working on the car but he's saying it has to do something with the wiring...also most of the lights inside my car are very dim i'd like to get that fixed too any help would be appreciated!
Old 10-08-2009, 07:25 PM
downhiller's Avatar
livin large
open the trunk pull the carpet from the back and reveal the light covers from inside. there are 2 clip things near the outer parts. push those in and twist half way. then the whole inner cover pulls away. this piece has all the bulbs attached and allows you to clean the contact points.
Old 10-08-2009, 09:05 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
what he said, and to answer your other point, rotate the knob that you pull to turn the lights on
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-09-2009, 06:36 PM
JohnMadd's Avatar
JohnMadd JohnMadd is offline
obsessed
Mein Auto: 1989 325is 03 330i ZHP
I bet your dad is right. Open the trunk and remove the left side panel of carpet in the trunk. Buy the antenna there is a small box, not the one for the antenna but around that area. Unhook that and pop the back off it and pull the inside out, it is easy and one piece. I bet it has a visible burn on the circuit board.
