Old 10-13-2009, 09:01 PM
galvinston galvinston is offline
galvinston
Mein Auto: 02, 330ci
Exclamation leaking oil!!!!
so i have oil leaking around my front driver side tire!. i know its oil, but not sure wether or not it's motor oil. could it be diff oil?. i find it odd the oil is dripping so far from the oil pan and drain plug.
Thanks for any input.
2006 x3 with the 3.0.
Old 10-13-2009, 09:21 PM
Mein Auto: 2004 X3 2.5i
Sounds like the Crankcase Ventilation Valve a.k.a. oil separator.
There are a few hoses that come off the valve that connect into the base of the dipstick tube and into the lower part of the intake manifold.
Could be a crack in one of those hoses, or the valve itself.
Short trips in colder climates without good highway runs can be a contributory factor.
Differential or transfer case leak would be more to the middle and further back.
Hopefully you are still under 50K miles for a straightforward warranty fix.
Old 10-13-2009, 09:23 PM
dharmadoggie dharmadoggie is offline
Mein Auto: 2005 X3
I have no particular experience with this, but I would be checking power steering fluid and brake fluid levels, as well as engine oil level. I suppose the trannny, if auto, has an oil cooler in or near the radiator, but I don't know how to check oil level for it. Antifreeze can seem like oil so it can also be suspect. If you are not a DIY type of person I suggest you take it to a competent mechanic, or the dealer if it's still on warranty. You're going to be there anyway, to get it fixed, right? :-)
2005 X3 3.0i, CPO, white, auto, adaptive xenon lights, stock suspension, premium pkg, cold weather pkg, heated steering wheel. Self installed: factory hitch, paint protection film, mud flaps
Old 10-13-2009, 09:40 PM
HT417's Avatar
HT417 HT417 is offline
Mein Auto: 2008 BMW X5 3.0si
If it's an extremely clear liquid similar to water it could be your motor mount. Have you noticed an increase in vibration through the car or the steering wheel?
Old 10-14-2009, 06:04 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Remember you have the skid plate down there, so oil will drip and flow down the skid plate to the floor, so impossible to locate with the plate in place. As adviced before, check all your fluids, but motor oil smell and consistency it's easy to detect. I you want, remove the skid plate and do a visual check, but everything is so tight in there that you probably won't be able to see where is coming from. Even to check the oil separator valve or hoses you need at least two hours to remove the necessary parts in order to "see it".
Old 10-23-2009, 07:29 PM
neahinla neahinla is offline
Mein Auto: 2006 3.0L X3
Had a similar issue. When did you get a oil change? After I got an oil change my x3 was fine for 2 months and started to leak oil around the same area as you are talking about. Check to see if any oil is leaking around the filter. Could be your oil filter ring is messed up and leaking oil.
Old 10-24-2009, 07:09 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Get it in and have it checked out, it won't get better. If you are still under warranty the dealer should fix this for you. Even if you are just out you might be eligible for a "goodwill" repair and I would certainly try for that before any DIY repair. Good luck and let us know what you found.
