E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
#26
#1- when cold, it is very noisy and pretty rough; if hit throttle, it acts like ready to stall (found info on this forum that it is common issue, related to software, and there is no fix yet – IS IT?). #2 is something that I would never expect from V8 engine, and from the luxury vehicle in general - it idles at ~700 W/AC, and drops to ~500 WO/AC. I always had Mercedeses before and never had this king of issues. Is this an issue or is it normal? Because when it idles at 500 you can feel vibration in the steering wheel – hate it. |
#27
The vibration at idle was a problem with me and I also owned a mercedes and currently own a lexus with NO NOISE at all. For what this car (528i 2008) costs, it should be as quiet as a mouse. But as you see, this is a common complaints with idle. BMW raised my idle a hair and it stopped. I have no idea what the stall issue is...
These vehicle are a bit complex under the hood and as long as the check engine light is not on, the BMW tells you most of the time "it is just the way it is". I would get multiple opinions and research it online. The noise I had was sooooo annoying that after 3 weeks with the car I wanted to get rid of it. Good luck |
#28
I had a similar problem with my 2009 525i, began after first service, 10200kms.Sent it back to the dealer , and was told that it was due to a faulty air meter.The same was replaced and now humming sound has disappeared. Shall wait and hear !
#29
My 2007 530i has this same issue, I've had it for a month now and it is really annoying. I took it to the dealer about 2 weeks after I got it and they said they couldn't reproduce the issue...ok! So I went back and had the service manager drive the car with me. He acknowledged the issue, but said he wanted to compare it to another 530. So we found another 2007 530 on the CPO lot and it did the same thing. Therefore his rational is that it was normal. I explained that just because it does the same thing in two cars doesn't make it "right".
To me it is a calibration issue. There is no reason that the idle should drop 50+ RPM (that is what mine does and that is when you get the vibration). I work for a company that does engine calibrations, there should be no reason why they can't hold an idle. I asked them if it was possible to update the engine calibration, at first I got a blank strare and then he said you mean the software? Yes I said. It seams to me if this is a consistent complaint, that BMW would retune the calibration. Anyway, my car is at the dealer and they are going to upgrade all the software - I guess I'll keep my fingers crossed. Chris _____ 2007, 530i |
#30
Hi all, I used to drive a 530 2005 in Dubai. I was lucky enough to have the notorious "lurch" problem of the tranny and eventually had it replaced at 85k km (I paid 30% of parts and 100% labor!).
![]() Sold the car, relocated to Doha earlier this year and just bought another 530 2007 with just 32000 km on the clock. The car even has a M5 kit and rims (worth 10,000 USD!) ![]() I noticed the same vibration when I first test drove the car. Since the car is still under warranty I did not worry about it at first. Over the past weeks it got more and more pronouncing by day which prompted me to bring the car to the dealer this morning. ![]() Similar symptoms; slight rough start when cold, vibrating at idle, it is bad enough both driver and the front seat passenger can feel it. The SA admitted it and did not say "that's the way it is" B.S to me. ![]() Will report back to the forum the outcome. Hope the dealer here is better than DUBAI. |
#31
Got my car today.
![]() First of all I have to praise the BMW dealer in Doha, Alfardan, they do take care of their customers. I turned my car in the morning yesterday and in 24 hours they car is ready. Their service center opens from 8~24 pm, 6 days a week, believe it or not. There were two major compliants from me, AC and the vibration at low RPM. They found the compressor is faulty and had it replaced, covered by the warranty. For the vibration, like many of you have experienced, they did a complete computer check and found no problem. They did bring the idle up a little bit and I can feel the difference. That has reduce 70% of the vibration. But everytime the RPM dips down the funny shiver is right back. ![]() My front break pads are due in another 2000 KM and I would ask them to raise the idle just a little bit, then the car would be perfect. Hope this helps!
#32
he-he i just paid $130 for injectors cleaning to make the idle better(and reduce vibration by that) which didn't help and monday taking my 545i to the dealer. Thanx for the bulletin info,hope it helps.
Do you guys also experience the delay in accelaration after a stop at the light?(a very slight but noticible)? i had 2 740i back in a day and niether of them did that.
#33
old thread. but anyway reading through it, i can come up with a few things that might be suspect.
does the car idle and have a very slight misfire that isnt prompting the check engine light to come on? is a motor mount possibly broken or defective? is there an exhaust hanger or mount that is loose or broken? just going off what was said, i would check those. i had this type of problem in my subaru which was due to an exhaust hanger issue. only at idle was it noticeable.
![]() *Der E38* manufactured: 7/01 color: anthrecite metallic wheels: style 89 E66, 19X9F 19X10R ext. lighting: 8000k D2S & LED plate light *want to get sport rear diff* |
#34
2007 530XI Black Sapphire with Beige interior and Premium, Cold Weather packages with NAV, 6-speed Auto |
#35
I have have experienced a few time the dealy of acceleration. It did not occure after the stop, it happened when the car was running in low speed. I dont think I can reproduce it with the SA. The engine was checked last time and everything seemed perfect. |
#36
i can only think that since the car idle at such a low RPM that it needs to get lil higher to accelerate than prev gen. tho my other car(acura tl) idles at about same RPM tho that one takes off like crazy from the line.(for the car like that of'cause)
#37
went to the dealer-they said that there's nothing wrong with the car~!!!!! even Helen Keller would know that something is off!!!
#38
#39
so fyi -- damonwhite sent me a pm and confirmed that his idle was turned up by turnersville bmw in NJ and he even gave me his cotact person there.
EDIT: the bracket seems to have made a slight improvement, but the vibration is still there Last edited by west76; 02-12-2011 at 04:09 AM. |
#40
so the part number on my receipt does not match the part numbers in the exhaust bracket tsb. i thought the dealer screwed up, but i found another tsb that has a step #4: Replace the stock 88Hz exhaust vibration dampener (1) with the 32hz dampener PN 18 10 7 506 145. Tighten to 21Nm.
#41
i take it you have the same low idle vibration problem? just so that you know, from my research, beyond the exhaust bracket thing, it seems like for some people their problem was the engine and/or tranny mounts. just something to keep in mind
#43
i initially thought it was just because mine's a diesel
but reading this then im guessing thats not the case as i've found other people with diesels in europe complaining of this issue you can only feel mine from the drivers seat. all my passengers (front and rear) think im imagining it
Thanks Eric1992 for your post, and the service bulletin. I had a good independent shop install the kit referenced in the SB (apparently the local BMW dealer stocks them which means they sell at least a handful each month). In addition my left engine mount was compressed significantly so I had that changed as well. Not sure why this would happen other than from regular engine torque but I only have 84,000km on the clock. Anyway, after both items were replaced the vibration was better but still there!
I took it today to chip tuning expert specializing in European cars locally and he bumped the idle up a little and now it is perfect ... no more complaints ![]()
#45
can anyone confirm for me that the bavtech software can adjust idle speed? i just had another bmw dealer tell me that idle speed is not adjustable.. so i guess i'm going to have to do it myself, or bite the bullet and drive an hour and a half to the dealer that did it for damonwhite.
#46
west76, I don't know about the bavtech software, but an independent BMW technician modified my idle about 100 RPM. It is now perfect with no vibration. The stock software can be modified. Good luck :-)
#47
Very happy with both the SA and the work....Paul at Bob Smith BMW |
#48
I have the same problem, it is very annoying to say the least.
1st, it cannot be fixed 2nd, you can play around with the idle, my dealership has done that, I have been there already three times for this issue - by increasing the idle you can almost get rid off the problem, almost, but not entirely. The problem you might encounter, when at a stop light and you let go of the brake, the var may lurch forward a little. You have two choices, accept it as it is or have the dealer try to adjust to an acceptable level, or seek legal action against BMW, and have them buy your car back. Sorry, but I have been dealing with this issue for months now, so did my ex wife who had the same car - she just got rid of hers and bought a Porsche - she is done with BMW because of how they handled this issue. Best of luck Philipp |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
