Old 10-14-2009, 08:42 AM
justin182 justin182 is offline
Mein Auto: '11 335d & '99 Z3 2.3
SES P1444 and P1450 Fuel System codes
I have two SES codes of P1444 and P1450. I cleared the codes hoping they would magically go away, but unsurprisingly they came back. Interestingly, they came back only after driving the car for a few seconds. They would not come on while idling.
These are the descriptions I've found for the codes:
P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit
P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit
From researching, it seems the fuel system is pressurized by 1-2 psi. My first thought is the gas cap. It is secure, tight, and I turned it past the click. I'm hoping it's just a leaking cap, but I've yet to get a replacement. Any other suggestions?
Thanks. -Justin
Old 10-14-2009, 10:37 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
The evap system is tested when starting up, and will trigger the SES light if it detects a leak.
By all means, get a new cap, but you may have to tear into the system, which lives behind the left rear fender liner.
Old 11-13-2009, 05:32 AM
I just wanted to follow up on this thread. Thanks to Ed's reply mentioning the left rear fender liner, I remembered that I had the left rear tire blowout a few months ago. It must have damaged the leak detection pump and caused it to fail. I had it replaced and the codes were gone.
