E36 (1991 - 1999)
Old 10-14-2009, 09:26 PM
Tom Nguyen Tom Nguyen is offline
Make your own Luck
Mein Auto: Lexus
Brake fluid DOt 4?
I need brake fluid because its low. And i know i need dot 4 fluid, but what brands do you recommend? I am getting some tmr.
1998 328i -SOLD- 06/06/2011
Handful of things I don't need Check it out:
http://www.bimmerfest.com/forums/sho...d.php?t=551778
Old 10-14-2009, 11:00 PM
merlin310's Avatar
merlin310 merlin310 is offline
Mein Auto: 2001 530i
I'd go with ATE Super Blue. Flush the system with that. Your brakes will thank you.
Old 10-15-2009, 11:58 AM
ECSTuning's Avatar
Instructor of the Stig™
Just and FYI brake fluid is not considered a top off fluid, if your fluid is low then there is most likely a problem...
But in the event that you are just low... I can offer you a large selection of fluid to meet your specific automotive needs, from OEM to racing. It's important to change your brake fluid every 1-2 years.
I would second what was said above, suggesting Super Blue! I am currently running it in several of my cars. 1998 M3, 2001 330i, and going in my 1987 325iS here in a few weeks!
You can find Super Blue as well as all of the other options for your specific application here:
http://www.ecstuning.com/BMW-E36-328...aign=postreply
Feel free to shoot me a PM if you have any questions!
Cheers,
Joe
Old 10-15-2009, 05:17 PM
e36mike's Avatar
e36mike e36mike is offline
Mein Auto: e30 e36 e368
is that the kind that changes color when its done? not sure, but i know theres some good stuff that changes color when you need to change it.
Originally Posted by tony5522 View Post
all these haters wish they could afford lexani rims..they look way better then bbs rims
Old 10-16-2009, 12:14 AM
PHARMDVIPER PHARMDVIPER is offline
auto>manual swap crew
Mein Auto: 2 black ones
^ well any brake fluid that needs to be changed will look dirty/have a different color to it
and+1 for super blue ATE.....you can get the super blue and the type200 which is the same thing but a gold/amber color......just switch back and forth and it will be easy to tell when your system has been flushed because it will bleed a new color
Old 10-16-2009, 02:31 AM
e36mike's Avatar
yea i know that. but i heard that theres one that drastically changes color, not like red to dark red, like it goes from green to purple for example.
Old 10-16-2009, 09:31 AM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
Why do you think you need dot 4??
Old 10-16-2009, 10:33 PM
Make your own Luck
Mein Auto: Lexus
WEll lol its said it in the Manual that's why i need dot 4.
Old 10-17-2009, 03:28 PM
FixItFaster
Dot 3 is plenty adaquate for driving on the street, even if it isent recommended by bmw. But I suppose there are alot of us who like a spirited drive here and there. But you don't need dot 4.
Old 10-17-2009, 09:53 PM
Make your own Luck
Mein Auto: Lexus
Oh well already bought it. Better to over prepared then under prepared right? haha. It doesn't cost much anyways
Old 03-07-2013, 03:24 PM
Arod65 Arod65 is offline
Mein Auto: '08 528i
rookie question
Where in the world do I pour the brake fluid? The power steering resevoir is in the place of a typical master cylinder.
Cheers,
Joe
Old 03-07-2013, 03:31 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
What car are you working on? This is the E36 section, you might try your models section.
Any errors in this post are purely Swype's fault, not mine.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 03-07-2013, 03:33 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Indeed a rookie question, because if you think the power steering resevoir is in the place of a typical master cylinder, you haven't been under many (i.e. any) hoods. The master cylinder is located in the same location in the E36 BMW as it is in 100% of all other cars sold in North America (the location of the master cylinder is dictated by the location of the brake pedal). The power steering reservoir is down low behind the alternator.
Edit: Assuming you're talking about the E36... If you have an E60 as your profile suggests, it's still in the same location, but it's covered up. Here is how you access it:
http://www.bimmerzone.com/category/T...ake_Fluid.html
1998 BMW 328is
1966 Pontiac GTO
Old 03-07-2013, 03:35 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
If you have an e36 then it goes in here.
Name:	e36 engine bay break.jpg
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 03-07-2013, 03:51 PM
I Am The Machine
I just pulled up a pic of the 08 528i engine bay, I can see how it would look like the PS reservoir is where the brake reservoir should be. Brake res is probably under a black plastic cowl cover.
// Chad //
You're a derbanana
