Old 10-15-2009, 08:55 PM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
Coolant pipe job completed!
Ok fellas I'm finally done. I replaced the notorious coolant pipe w/o removing the motor or the heads and oil pan. I will tell you that it is very time consuming but it can be done.
i did have a couple of hiccups but the were resolved. A special thanks to KEIF and
BIGRAM67. I'm not a photographer but i did takes some pics. HOPE THIS HELPS.
ID:	204762   Click image for larger version
ID:	204763   Click image for larger version
ID:	204764   Click image for larger version
ID:	204765   Click image for larger version
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 10-15-2009, 09:48 PM
07841-tb's Avatar
more coolant pipe pics.
Part two from the previous thread.
ID:	204769   Click image for larger version
ID:	204770   Click image for larger version
ID:	204771   Click image for larger version
ID:	204772   Click image for larger version
2002 BMW 745Li
Old 10-15-2009, 09:57 PM
gfd1989 gfd1989 is offline
Mein Auto: SOLD
Wow. Impressive. How long did it take, and how much money did you save?
Old 10-15-2009, 10:05 PM
07841-tb's Avatar
Originally Posted by gfd1989 View Post
wow. Impressive. How long did it take, and how much money did you save?
it took me 7 days to complete it. I was very careful so i just took my time and did not rush. I saved my self $6000.00. The dealer wants around $6500 starting off.
2002 BMW 745Li
Old 10-15-2009, 10:21 PM
cigars cigars is offline
Mein Auto: 745i
wow!! quite impressive indeed. How much were the parts?
Old 10-15-2009, 10:29 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
wow thats crazy!
'08 BMW 535i - Sport - Sport Trans - JB4 - Catless DPs - Intake - E85 -
'07 SUZUKI GSXR-750 - Gray/Black - Akrapovic Titanium Exhaust -
'03 BMW 525i - Sport -
'98 Ford Expedition - 5.4L - 4WD - Eddie Bauer - 8 seater -
'03 BMW 745i - GONE -
'09 HONDA CBR600RR - GONE -
Old 10-15-2009, 10:31 PM
07841-tb's Avatar
Originally Posted by cigars View Post
wow!! Quite impressive indeed. How much were the parts?
coolant pipe + REAR ORING : $78
valley pan: $110
valve cover set: $140
intake gaskets: $15
timing cover set: $35
water pump: $110
spark plugs: $50
antifreeze: $40
chf11s fluid $20
oil pressure switch: $10
WELL WORTH IT! I have more pics on maybe page 3 or 4
2002 BMW 745Li
Old 10-16-2009, 02:46 AM
bembo19 bembo19 is offline
Mein Auto: E65 745
well that certainley shed light on the problem ! i take it you replaced some parts while you were at it and not because it needed them ??
Old 10-16-2009, 02:50 AM
Seven11's Avatar
President
Mein Auto: BMW
my dealer recommended that i replace colant hoses, Tstat and expansion tank.
how much is that to replace?
Old 10-16-2009, 03:03 AM
Mein Auto: E65 745
great stuff ! i take it the red arrows are to indicate what parts you changed ?
Old 10-16-2009, 03:38 AM
Mein Auto: E65 745
why the hell you'd need to do the expansion tank ! ? It was a water leak ! not head gasket failure !
Old 10-16-2009, 06:47 AM
07841-tb's Avatar
Yes, I figure while i'm in there it would be a good idea.
2002 BMW 745Li
Old 10-16-2009, 06:50 AM
07841-tb's Avatar
Not sure, have not experianced any issues related to those parts.
2002 BMW 745Li
Old 10-16-2009, 07:23 AM
07841-tb's Avatar
Some just showing the faulty pipe o-ring and showing the oil pan still in place with out removing.
2002 BMW 745Li
Old 10-16-2009, 07:30 AM
1bad540's Avatar
1bad540 1bad540 is offline
Maybe this should be stickied w/a diy, Did you do this yourself??
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 10-16-2009, 07:35 AM
1bad540's Avatar
I just did my 3ser tstat, rad,hoses,belts,Exp tank.pulley.water pump. Indy at $1,260
[SIGPIC]
Old 10-16-2009, 08:00 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
I just want to say you are the f'ing man for doing all this and for providing pictures so everyone else can see how you did it -- and to show that you can do it from the top without pulling the heads!
Did you have to do anything special to get the valley pan out without pulling the heads, or did it just slide out toward the front?
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 10-16-2009, 08:03 AM
07841-tb's Avatar
Originally Posted by 1bad540 View Post
maybe this should be stickied w/a diy, did you do this yourself??
yes, me and my cousin took on this task and i save a good chunk of money.
In the beginning i called bmwna for a good will repair but of course they denied me.
2002 BMW 745Li
Old 10-16-2009, 08:13 AM
Judd944 Judd944 is offline
Mein Auto: 03 745i Sport / 01 986S
Great job man, keep the photos coming ! I will take photos when I do the next set of repairs on the 7.
2003 745i Sport Sterling Gray/Black
2001 986S Seal Gray / Boxster Red
Past:
98 540i Sport
6 944's
Old 10-16-2009, 08:37 AM
07841-tb's Avatar
ONCE YOU REMOVE THE INTAKE THE VALLEY PAN IS RIGHT THERE. JUST REMOVE ALL THE BOLTS LIFT UP WHICH WILL EXPOSE THE COOLANT PIPE THAT SLIDES OUT FORWARD. YOU WILL HAVE TO REMOVE THE RADIATOR. HERE ARE OTHER PICS. THANKS GUYS FOR THE SUPPORT.
http://www.bimmerfest.com/forums/sho...453&highlight=
2002 BMW 745Li
Old 10-16-2009, 09:13 AM
Jerry 745Li Jerry 745Li is offline
Mein Auto: 03' 745Li & 12' Hybrid7
Wow, and I was all proud that I successfully changed my spark plugs! This is one major job that I wouldn't attempt.
Jer
I don't have all the answers, but I can do one helluva Google search
Old 10-16-2009, 09:48 AM
what procedure did you use? did you follow steps from a BMW manual? how about any special tools that needed to be bought / rented?
If you get the time try and write up a list of tools needed, and the order of things you removed, etc. It would be great to look at the steps of the job and try to estimate repair time and space needed.
also you say it took you 7 days but that was just working a few hour each evening right? not 8 hours a day.
Past:
98 540i Sport
6 944's
Old 10-16-2009, 09:59 AM
Once again, excellent work !
I see the difference from the rear crossover pipe on the E39 540i I had and this car is the pipe is now under the valley pan instead of on top of it.
My E39 had a leak at the rear crossover pipe and while I was in there I replaced the vally pan, rear vacuum plate, intake gaskets, etc. Here are two photos I took that are similar to yours. Also I did not need to remove the radiator from the car to do my repair. The E65 is more involved but can be tackled!
Name:	rear crossover pipe.JPG
ID:	204810   Click image for larger version
Name:	intake removed.JPG
ID:	204811   Click image for larger version
Name:	v-pan removed.JPG
Past:
98 540i Sport
6 944's
Old 10-16-2009, 10:40 AM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Wow excellent job. How does it run from the repairs you did?
Old 10-16-2009, 11:28 AM
07841-tb's Avatar
Originally Posted by johndade View Post
wow excellent job. How does it run from the repairs you did?
runs very good especially since i replaced the spark plugs while i had it open.
2002 BMW 745Li
