Old 08-09-2010, 02:33 PM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
Originally Posted by m50b25 View Post
hmmm, wasn't it easier to get that magic pipe from allgermanauto instead?
same money but way less work
Rather go factory specs. The new allgermanauto pipe has'nt been out long enough for me.
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 08-09-2010, 02:34 PM
bimmer80 bimmer80 is offline
Mein Auto: 745LI
The magic Pipe is $78? I bought the original one from the dealer and it was $110 with the rear o-ring. Also from what I been told of Dealer parts is that I get 2 years of warranty and if within that time the part is broken or has failed, BMW will replace it and change the defected part for you with at no charge as long as you have the original receipt.
Allgermanauto:
AGA-N62-6061 Cooling Pipe Exp $548.00
http://allgermanauto.com/product/index.html
Old 08-09-2010, 02:40 PM
07841-tb's Avatar
Hey Bimmer80, did you remove that antifreeze from that area?
2002 BMW 745Li
Old 08-09-2010, 02:44 PM
Mein Auto: 745LI
Yes, im still working on it. Im taking my time and not doing it in a rush.
Old 08-09-2010, 03:18 PM
E92-Lighting's Avatar
Mein Auto: 335i
thanks for the information
BMW ACCESSORIES and PARTS
Old 08-09-2010, 03:26 PM
Mein Auto: 745LI
So when I replace the Coolant Pipe, I just put it together leaving it dry and when its all put back together just put coolant in the coolant tank right?
Old 08-09-2010, 03:29 PM
m50b25 m50b25 is offline
Account closed at users request
Mein Auto: BMW 745
are you serious?
there should not be any coolant in this reservoir ! Its there just because your pipe was leaking!, otherwise whats the point of this pipe?
Old 08-09-2010, 03:37 PM
Mein Auto: 745LI
are you serious?
Sorry if I did not make it clear. The reservoir which is where the Coolant Pipe should be dry. The coolant tank I was talking about is on top of this picture.
Old 08-09-2010, 03:52 PM
Mein Auto: BMW 745
sure, this one should be full, otherwise you will get a message on your idrive: like coollant is low
also make sure you bleed the air out the system. check your both hoses after start and temperature gauge.
both of them should be hot after thermostat has opened. But i think this system should bleed the air automatically.
Old 08-09-2010, 08:55 PM
07841-tb's Avatar
Yes, fill it up to max indicator line. You will see that on the cap.
2002 BMW 745Li
Old 08-09-2010, 09:33 PM
rustar's Avatar
rustar rustar is offline
Mein Auto: 745i
All German Auto kit includes "Cam. Adjuster O-ring ($3.61 each)" and "Water Pump Gasket". Why, you aren't touching these are you?
Old 08-10-2010, 03:55 PM
kpeterson kpeterson is offline
Mein Auto: 2002 745i
the coolant pipe replacement went well if you take yoru time. On the 2002 745i where is there a temperature guage. i dont see one. and that is NOT a stupid question...haha.
i bled mine for an hour with the cap off then rdrove it for 30 minutes and let it sit overnight before putting more coolant in it.
All isgood now.
Old 08-10-2010, 03:57 PM
ok here isone for you. where and why do they send cam adjuster gaskets int eh all german kit? i did the water puimp before and yes i wanted to replace the water pup gasket again. Also talking to my local guy (BMW of Mt. Laurel) they said to put on a light skim of permatex.
Old 08-10-2010, 09:29 PM
rustar's Avatar
Mein Auto: 745i
i dont know why they include, did you use it?
"2 07-11-9-903-596 Cam. Adjuster O-ring ($3.61 each) $7.22"
Old 08-12-2010, 05:04 PM
i talked to my local bmw dealer. they said DO NOT pressure the system to 15 psi. you will blow th eseals out agian.
Old 08-15-2010, 11:57 PM
Mein Auto: 745LI
Hey Guys,
Im putting the engine back together after about a week of work. I have replaced the water pump, thermostat, coolant pipe and a few gaskets. Also the alternator mounting bracket which broke when being disassemble for the coolant pipe change. I order all the parts from the deal and this part was special order that should get here by Wednesday of this week. I was looking at replace the Cover Cap with Gasket for Engine Block Valley Part # 11147507278 which is # 1 in the picture below because they don't sell the seal/gasket that's on it separate. The dealer has to special order this part as well and will take about 3 business days to get here for about $140.
I found some sites online that have it and say its "Manufacturer: GENUINE BMW" and cost between $75 to $90.
Do you guys think I should order it online or somewhere else like the dealer?
Thank you.
http://europartsamerica.com/parts/pr...ls/11147507278
http://www.koperformance.com/online_...-11147507278-9
http://www.aboveallmotorwerks.com/Pr...7507278_S.aspx
Old 08-17-2010, 05:17 PM
valley pan
i replaced mine. it came with a new gasket
Old 08-19-2010, 10:22 PM
rustar's Avatar
Mein Auto: 745i
I just fixed coolant pipe leak also. $830 for the kit, + $650 labor including coolant pipe, valve cover gasket seals and spark plug replacement. And 180 for new battery
Old 08-26-2010, 09:24 AM
Mein Auto: 745LI
Hello Guys,
I have finally finished the coolant pipe replacement last night after 2 weeks or so.
I also changed some other things like gaskets, hoses and water pump with the termostat while I was at it with the engine taken apart. Just 2 things broke on the process of disassembly, the alternator bracket and I believe it was the passenger VDO sensor that is in the back of the valve head. Other then that everything went smooth and i'm glad I have the car running. It took a while but was a good experience and I got to know my car better so future reference.
I would like to Thank everyone that helped me and Bimmerfest for having a great BMW community.
Thank you.
Below are some links that I used for reference on this project.
http://www.bimmerfest.com/forums/sho...d.php?t=417251
http://www.bimmerfest.com/forums/sho...d.php?t=405453
http://www.realoem.com/bmw/partgrp.d...id=47777&hg=11
Old 09-30-2010, 09:25 AM
micosan micosan is offline
Mein Auto: 550i
Deleted
2007 550i Sapphire Black, Prod. Date 11/2006, Sport Pkg, Comfort Access, Navigation, TX, USA
Old 12-03-2011, 06:08 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
Wow great work man. You guys are amazing. Who needs the stealers when we got more experience BMW owners here.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 02-24-2012, 06:51 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
AGA Pipe + DIY (ok, you got to be pretty good) is 2 thumbs up !!!!
btw, we are now an authorized dealer for AGA
Pipe is available at:
http://www.bimmerzone.com/BMW_Perfor...-PIPE-N62.html
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 02-24-2012, 07:55 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i; 750Li; Yukon Denali
Great job bro!
Old 04-20-2013, 07:51 PM
van556 van556 is offline
Mein Auto: '97 528i, 5-speed
What's the purpose of this coolant pipe that BMW didn't cast it as one piece? Would it be ok to JB Weld at both ends?
I've used JB Weld on a few radiators in the past and that held up well to the pressure and temperature; never giving me any problems.
'97 528i, 5-speed
OEM Angel Headlight from '01+
OEM LED Taillight from '01+
Old 04-21-2013, 03:48 AM
bimmerzone's Avatar
Supporting Vendor
The failure point is actually the oring, and not the pipe itself.
The BMW pipe is one piece, but that means its hard to take out, hence the AGA being a 2-piece design
