E46 (1999 - 2006)
Old 10-16-2009, 12:36 PM
lexrace24 lexrace24 is offline
Mein Auto: 330CI
Exclamation P0446 Evap Circuit Malfunction
I’m having trouble diagnosing a SES code p0446, which is telling me there an evap emission control vent circuit malfunction. With 222,000 miles on the car the first part I change was the gas cap, thinking this may be the cause but the SES light is still on and the code still appears. Is there any schematic I can use to read the wire or troubleshoot this problem?
Old 10-16-2009, 01:07 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Replace your gas cap. Code will go away.
Old 10-22-2009, 12:53 PM
Mein Auto: 330CI
I replaced the gas cap and the p0446 went away, but now i have three different codes
P0171 Bank 1 is lean
P0174 Back 4 is lean
P0456 EVAP Leak Monitor Small Leak Detected
I have also noticed there is a high pitch whistling sound when the car is under hard throttling. I do a K&N cone air filter, I will check the wye fitting going to the throttle body for any crack’s. Is there any other possible suggestion that can assist me in troubleshooting?
Old 10-22-2009, 01:30 PM
smolck's Avatar
ROLL TIDE!
I think you have it nailed. When I had a cone filter and CAI kit mine whistled even with no cracks. Most likely the little neck that runs to the ICV is cracked.
