Old 10-16-2009, 06:03 PM
sunnyyan sunnyyan is offline
Mein Auto: 05' X3 3.0I/05' Honda S2k
Rear passenger footwell soaking wet?
Dam it rained like hell early this week in SF bayarea. Just found out my rear passenger footwell is soaking wet for unknown reason. i vaguely remember someone posted here with the same issue before but no practical cause/solution found. Can someone chime in with a possible reason and DYI instructions on fixing this?
Car is out of warranty so I prefer to fix this issue without taking to dealer. Thanks in advance.
SY
Old 10-16-2009, 07:02 PM
Mein Auto: 2004 X3 2.5i
Car parked outside, upwards on a SF hill, during the rainstorm?
Sunroof drains cleaned since last winter?
Window regulator or speaker replaced on right rear within the last year?
Vapor barrier replaced properly?
Old 10-16-2009, 07:19 PM
PPXYZ PPXYZ is offline
Mein Auto: BMW X3 2009 AT
SY
Seems to happen to lots of cars (not just BMWs) with pano roofs if that is indeed the problem. Seems like soaking wet means lots of water coming in from above?
http://forums.bimmerforums.com/forum...d.php?t=641399
Old 10-16-2009, 10:43 PM
xsogo xsogo is offline
Mein Auto: 2006 X3
panarama roof! I had the same problem last month. fortunately, My X3 is still under warranty. The dealer took care of it and gave me a brand new 328i during the weekend.
Old 10-17-2009, 05:46 AM
codog2 codog2 is offline
Mein Auto: 5
I've brought my 05 in three times during the last three months (I first noticed this two weeks left on the orig warranty)
The dealer said first it was clogged sunroof drains, then the 2nd, 3rd times vapor barrier problems. The roof is always dry, and there was window regulator repair done to one of the rear windows (first owner). Waiting for the next heavy rain then I'll call BMWNA.
I'm not sure if it is just dealer incompetence (big dealer in Boston), or BMWNA is giving me the run-around and not authorizing the dealer to truly fix the problem because of the high cost to repair (the revised sunroof cassette part is $3k alone). Maybe they're hoping I'll trade the car in to another dealer.
My first service receipt actually listed the sunroof cassette part as special order. It was never actually replaced - the SA hinted something about BMWNA not authorizing the replacement.
Anybody know if I have any legal recourse for BMW refusing to authorize a repair while the car is still under warranty?
XSOGO what did they do to your pano roof to repair the problem and what year is your vehicle?
Old 10-17-2009, 05:53 AM
Patrick Patrick is offline
Banned
Mein Auto:
Have a look (a long one) here:
http://www.bimmerfest.com/forums/sho...d.php?t=259095
Good luck.
Old 10-17-2009, 11:21 AM
Mein Auto: 2006 X3
First, they told me that they might have to clean the clogged sunroof drains. But in the receipt ,they just replaced the sunroof frame seal with updated part. Too much rain in texas recently helped me test it. It has been fixed.
Old 10-18-2009, 03:19 PM
bmwadam bmwadam is offline
Long LIVE ZFHP22!
Mein Auto: 2006 330i 6MT Sport
Ok I have delt with that before!! It took my dealer over 7 Repair attempts to fix it, had the car been out of warranty, I would have done it myself. If it is JUST in the floorboard I am 99% POSITIVE it is the vapor barrier. The design of your door allows water to drain through the door and out a weep hole in the bottom. The vapor barrier keeps the moisture out of your car during this process. If there is ANY hole at all in the barrier, no matter how small you will get pools of water in your foot well. After a hard rain look in your door seal, and see if you see a small stream of water. It is hard to see however so look close.
Even though they said they fixed it, I doubt they did. What they do is try to re-seal it. This is lunacy. The only way to truly fix it is to replace the vapor barrier inside the door. You can use the OEM barrier, OR have an aftermarket trim shop acustomed to working on BMW's do it for you. The aftermarket route should only cost around 150 for both rear doors as they do not use the OEM barrier but an aftermarket vapor shield which does the same thing at a fraction of the cost. I have done this myself on an e46 (same design) but alas I do not have pictures to show. There should be a DIY write up somewhere on this board or the net as it is a VERY common problem with these cars. I even heard of a guy who made his own barrier out of materials found at home depot! This is not a difficult procedure, with the proper research etc, you should be able to pull it off.
Good luck to you! Dont trust the dealer on this one, this is something many of them routinely muck up because they generally do not have the barrier in stock and they just want to throw some sealer on there and get you out the door.
The DIYer BMW rant:
Cursed plastic impailor waterpumps, plastic bleeder screws, m20 timing belts, anti rattle clips, window regulators, CDV valves, digital odometer displays, evaporative emissions circuit, aux cooling fan, sunroof drains, heator cores, door seals, control modules, M62 cam covers and of course GM autos.... (more to come)
Old 10-18-2009, 04:41 PM
Mein Auto: 5
bmwadam,
Should I see this stream with the door closed? I've tried going in the front door and climbing in the back when its raining. Is a vapor barrier leak visible this way?
It rained pretty hard today - I've got to go check and see how it held up this time
Old 10-18-2009, 04:55 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
That is absoultely insane to try to reuse the vapor barrier considering they cost all of $17 and change. They spent more in man hours scractching their behinds.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 08-27-2015, 02:46 PM
jayjay31 jayjay31 is offline
Mein Auto: X3
HI Have recently noticed both rear side footwell wet after rain ! i have taken both door cards off, NS had no vapour seal at all and i could see water coming in so I have replaced and sealed correctly, the OS had the vapour seal on and no water was coming in so im wondering why this side is wet ?
My X3 is 2004 model withOUT a sun roof , i checked both drain holes both doors ! and front door drain holes all seem to be clear !
Is there any where else water can come from that could be causing the wet on the OS rear footwell ? i am hoping the NS will be sorted now
cheers
JAY
Old 08-28-2015, 12:16 AM
mikesmith2 mikesmith2 is offline
Mein Auto: E46 330d M Sport
My leak turned out to be a very small hole in the butyl tape that holds the vapour barrier to the door.
Mine was on the front door, but because the front of the car was pointing uphill slightly the rain ran along the inside door trim in to the rear footwell.
It took over 20 mins with a hose pipe soaking the outside of the vehicle to determine where it was leaking, this was done with the door cards off, drivers seat removed and carpet lifted
Old 08-28-2015, 07:06 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
good fest vapor barrier info
http://www.bimmerfest.com/forums/sho...=1#post9247299
https://www.google.com/url?sa=t&rct=...K9JBDBp6lQVC_Q
I thought you might be interested in reading this web page:
http://www.bimmerfest.com/forums/sho...errerid=343410
good link on the vapor barrier sealing and drying out the X with a fan etc
Old 08-28-2015, 07:50 AM
get a good "wallpaper style roller and heat gun/hair drier
also ....on your rear vapor barrier seal everyone down here uses a heater and small roller to ensure a good seal on the 3m stuff......
http://www.bimmerfest.com/forums/sho...d.php?t=816463
Name:	Screen Shot 2015-08-28 at 8.51.54 AM.png
